96 4.0 Explorer will not start
My wifes X was running fine today,then she stop at the store got what she needed,went to leave .NO start.It cranks fine,has fire at plugs.HHHMMmm Got the fuel pressure gauge,hooked it up.Yep you guessed it no fuel pressure!!
My Questions are 1} Where is the is the fuel pump reseat switch?{No I don't have the owner manual,Bought the X used}. 2}How hard is it to put the fuel pump in the tank?
Thanks for any Help
Jeff
Thanks for any Help
Jeff
to download your owner's manual goto
https://www.fleet.ford.com/maintenan...ls/default.asp
put in the info and download away (only seems to work w/ MSIE)....
Check the fuel pump relay. It's a fairly common problem and an easy fix. The relay is located in the power distribution box under the hood by the battery. This chart should help identify it: http://autozone.com/servlet/UiBroker...3d800ba8f3.jsp . You'll have to scroll down to the right year and blow it up to read it.
Fuel pump
Just finished my son's a couple of weeks ago,
2 hrs start to finish,
Pump complete 150.00 NAPA, retainer ring 29.00(ford only part) in BC, Canada.
Clean the top of the tank well so no dirt falls inside, quick way to kill new pump..
Make sure you get a new sock (internal filter) for pump. and remember to change the main filter as well, reduces back presure..
you will need a release tool to disconnect the pump and the external filter...
Dont forget to release the fuel pressure in the line before opening connections...
Good luck
Good luck
Good luck
Good luck
96F150-4.9
09-26-2016 12:02 AM
ExPACamper
49
03-31-2015 03:52 PM
