Rear Axle Ratio - Ford Truck Enthusiasts Forums
Rear Axle Ratio
Old 03-28-2005, 04:53 PM
coleyct coleyct is offline
coleyct is starting off with a positive reputation.
Rear Axle Ratio
Just found thisdd site and registered today. Have a'92 F-150, 5.0 engine, Automatic, with 134,000 miles. I only get 13 mpg around town and think the differentail ratio is to steep. I think the "trailer package" came with a ration somewhere in the 3.75 range. I also think a 3.53 ratio is available. Any have expierence in this field? Sure would like some help in trying to improve my mileage. Rairly tow a light weight trailer very short distances(les than 50 miles)
Thanks for any help or suggeations.
See Ya!
Tony
Old 03-28-2005, 05:10 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
There's a sticker on the driver's side door jamb that will tell you your ratio.
18= 3.55
19=3.08
H8=3.55 limited slip
H9=3.08 limited slip
Changing the gears will cost you about $1000 per axle (front too, if it's 4x4). So take that into consideration. Also, even if you swap to 3.08 gears, you can expect maybe 3-4 mpg improvement. I said MAYBE.
Old 03-28-2005, 06:18 PM
Schmids4.9l's Avatar
Schmids4.9l Schmids4.9l is offline
Schmids4.9l is starting off with a positive reputation.
actually you can buy gear, ring, and pinion sets from summit racing for 180 bucks.
Old 03-28-2005, 06:32 PM
andym's Avatar
Yes, but unless you've done it before, or have someone who knows what they're doing to help you, I wouldn't recommend it. The margin for error is too small - there's no "close enough" or "almost". It's either dead on, or completely wrong.
Old 03-28-2005, 07:12 PM
frdtruc1 frdtruc1 is offline
frdtruc1 is starting off with a positive reputation.
I had this same inquiry in the Clutch, Trans, Differential,[/U] etc[/U] forum. Was advised to check the metal tag attached to the differential cover. It will give you a lot of information that you can reference. In my case, it was a lifesaver. The door in not orig and would have thrown me off.
Travisio Travisio is offline
Travisio is starting off with a positive reputation.
[QUOTE=andym]There's a sticker on the driver's side door jamb that will tell you your ratio.
18= 3.55
19=3.08
Isnt H9 3.55 LS and H8 3.08 LS. I could be wrong on this?
Old 03-28-2005, 08:17 PM
mkmchu's Avatar
mkmchu mkmchu is offline
mkmchu is starting off with a positive reputation.
Do those codes apply regardless of year and model? I would assume so. But, then there is that word "assume" again.
Thanks
Old 03-28-2005, 09:11 PM
tex94F250's Avatar
tex94F250 tex94F250 is offline
tex94F250 is starting off with a positive reputation.
Check the tech section for Ford Axle codes in this site. They are all listed.
Old 03-28-2005, 11:57 PM
mkmchu's Avatar
... confusion level rising...
Here is a clip from the article I found in the tech section.
Axle Decoder Chart
Code Ratio Capacity Maker Type Yr
12 2.73 3800 FORD REG 1991
17 3.25 3300 FORD REG 1971
17 3.31 3800 FORD REG 1995
18 3.08 3800 FORD REG 1991
19 3.55 3800 FORD REG 1991
But, the postings in this thread call for the 18 code to be 3.55 and the 19 to be the 3.08. I hate to come off as a grammar lawyer. But, I am trying to learn and understand.
If the code on the door on my truck is 18. Which ratio am I running?
Thanks and sorry for being picky.
Old 03-29-2005, 04:36 AM
tex94F250's Avatar
Okay, on this page, top right in Blue letters, TECH ARTICLES, to top left in grey area, DECODERS, CODES, CHARTS, to FORD AXLE CODE CHART. 18 = 3.08.
Old 03-29-2005, 12:38 PM
so 19 is 3.55? i guess i dont have 3.08's. i was wondering why my speedo shows my speed at 5 mph faster than what im actually going.
Old 03-29-2005, 12:43 PM
Here you go Tex94!
25 4.10. 5300 FORD REG 1991
29 3.55 5300 FORD REG 1991
35 4.10. 6250 FORD REG 1991
36 3.73 7400 DANA REG 1980
39 3.55 6250 FORD REG 1991
45 4.10. 7400 FORD REG 1991
49 3.55 7400 FORD REG 1991
65 4.10. 8250 FORD REG 1991
69 3.55 8250 FORD REG 1991
72 4.63 11000 DANA REG 1991
73 5.13 11000 DANA REG 1991
H5 4.10. 3800 FORD LIMITED SLIP 1991
H7 3.31 3800 FORD LIMITED SLIP 1995
H8 3.08 3800 FORD LIMITED SLIP 1991
H9 3.55 3800 FORD LIMITED SLIP 1991
B5 4.10. 5300 FORD LIMITED SLIP 1991
B9 3.55 5300 FORD LIMITED SLIP 1991
C5 4.10. 6250 FORD LIMITED SLIP 1991
C9 3.55 6250 FORD LIMITED SLIP 1987
D5 4.10. 7400 FORD LIMITED SLIP 1991
F5 4.10. 8250 FORD LIMITED SLIP 1991
W5 4.10 8250 FORD LIMITED SLIP 1995
Old 03-29-2005, 12:58 PM
i know ive posted here 3 times in a row, but im confused.
the origninal axle in my truck was 19 (3.55). but the guy i bought it off of put in a new rear end, and i dont know what it is, alls i know is that the speedo shows at 5 mph too fast. does that mean theres 3.08s' or 3.73's, or its because my aftermarket C-6. it used to have the mazda 5 speed.
sorry for the added confusion.
Old 03-29-2005, 10:27 PM
mkmchu's Avatar
This has side tracked a little. What about the original question? What sort of upgrades are in order?
Gear ratio with 3.5L Ecoboost boss1982 2009 - 2014 F150 13 03-25-2015 08:56 AM
1977 F100 T18 to ZF5 transmission swap tndallas 1973 - 1979 F-100 & Larger F-Series Trucks 17 02-10-2014 07:20 PM
overall gear ratio - '95 F150, 5 sp. manual? huntbywalking Ford Inline Six, 200, 250, 4.9L / 300 3 02-07-2013 02:23 PM
Changing Rear axle gear ratio icobod 1987 - 1996 F150 & Larger F-Series Trucks 16 09-21-2011 05:40 PM
Rear End swap -'53 F100 Narwhal 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 07-26-2004 02:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
