95 F350 Front Differential ID
I am a new member to this site and am hoping you guys can help. I tried a couple of searches with no results. I want to put a detroit locker in the front differential of my truck but am having a hard time finding what differential I have. I assume that it is a dana 60 becasue it has a 10 bolt cover and looks the part. However I can't recover the bill of material number. The only numbers I have found are 620093R and 4228. The people at trachtech tell me those numbers don't help. I basically need to know how it is geared as well. The door tag has the code C9 which I believe means the rear is a limited slip 3.55 ratio.
VIN: 2FTHF36G8SCA09399
Thanks for you time and for any help or guidance I recieve.
Front Detroit Locker
Putting a Detroit locker in the front differential is very dangerous unless it is ONLY used off road in soft material. If you've ever had one you would know why.
Use it instead in the rear housing which will either be a 10.25 or 10.50 ring gear housing. Check the year.
The front differential would work well with a clutch style limited slip package.
A combination of the two should allow the truck to climb walls and get noticeably worse fuel economy.
svujke
05-09-2016 09:51 PM
troy payne
06-25-2004 08:07 AM
MustangGT221
05-15-2003 07:30 PM
