dynamat? - Ford Truck Enthusiasts Forums
dynamat?
Old 03-28-2005, 12:02 PM
fish-albuq's Avatar
fish-albuq fish-albuq is offline
fish-albuq is starting off with a positive reputation.
dynamat?
whats the best sound/heat shield? they have some dynamat on e-bay its only 36 square foot. how has anybody done this? thanks again
Old 03-28-2005, 12:11 PM
Randy Jack's Avatar
Randy Jack Randy Jack is offline
Randy Jack has a good reputation on FTE.Randy Jack has a good reputation on FTE.
Fish -
Check out the thread below. Lots of opinions on the topic and this was a good synpopsis.
http://www.ford-trucks.com/forums/sh...d.php?t=338480
The Dynamat is very pricy. Also, I recently saw something very similar in the JC Whitney Truck catalog that looked very similar (alum faced, glass reinforced, non-absorbent, etc) that was much better priced.
Old 03-31-2005, 03:49 PM
fking1's Avatar
fking1 fking1 is offline
fking1 is starting off with a positive reputation.
Dynamat is good , but , expensive; around $125 for 36 sq ft. Many Corvette people use Frost King from Home Depot or Lowes to sound insulate. Very inexpensive. I put a sheet under my 55's floor mat & noticed a difference. Plan to get more and insulate where ever possible.
Fred
Old 03-31-2005, 05:57 PM
fatfenders56's Avatar
fatfenders56 fatfenders56 is offline
fatfenders56 has a good reputation on FTE.fatfenders56 has a good reputation on FTE.fatfenders56 has a good reputation on FTE.
Randy, that thread was "before my time" but it was a good read. ThanksFF56
Old 03-31-2005, 08:32 PM
Jet Jock Jet Jock is offline
Jet Jock is starting off with a positive reputation.
fking
Read the fine print the 32.95 for shipping. That is a ripe off. I ordered mine from www.quietride.com they have a package they recommend including dynamat and other insulation for my F-1. Custom Classic Trucks mag Feb 2005 had a kit they installed in their Project F-1 that came from Quiet Ride. They mag folks liked the kit.
Jet Jock
"I drive a 'girly' 302 because, when I want to go fast, I go to work"
Old 03-31-2005, 10:25 PM
fatfenders's Avatar
fatfenders fatfenders is offline
fatfenders has a good reputation on FTE.fatfenders has a good reputation on FTE.fatfenders has a good reputation on FTE.
http://www.edesignaudio.com/product....pid=25&cur=USD
This should be a link to Elemental Designs. About an hour from where I live. They sell eDead. Its a little thicker than Dynamat. It may not be quite as good as Dynamat but in my opinion its a lot better deal at $1.50 a foot. That's half the price. It's definitely better than what I am using, and my road noise is gone. eDead is designed to kill subwoofer induced panel rattles. That isn't a simple task and this stuff does it. It is heat resistant. They also sell a liquid deadener but it's ugly aqua blue. Suppose it wouldn't matter once the rug is down.
Old 04-01-2005, 12:18 AM
55forder's Avatar
55forder 55forder is offline
55forder is starting off with a positive reputation.
How many square feet do you suppose it will take to do a 53-56 pickup? I also noticed that fenders said he wouldnt use on the roof of the cab. Why not?
Rich
Old 04-01-2005, 05:23 PM
fatfenders's Avatar
Quote:
Rich
I was referring to Peal and Seal, which has an unknown heat resistance (to me). It's not needed up there anyway IMO. The normal foil over insulation works just fine on the roof. The sound deadeners work particularly well on the road noise, rattles etc, which will typically be coming from the lower half of the truck. I only used deadener on the floor, the corners behind my speakers, door inspection panels. The stuff works like a heat sink. Full coverage of the entire cab is just adding weight IMO. The stuff is heavy, as it's meant to add density to sheetmetal. I used insulation of one form or another behind virtually everything. So far so good, I don't think I'll be adding much more.
About 50 squares would be a good start for real decent sound deadening.
Old 04-01-2005, 07:03 PM
286merc 286merc is offline
286merc is starting off with a positive reputation.
I went the Home Depot route on my 26T coupe. Without it I couldnt hear myself fart much less the radio. That cab is about on a size and noise par as an Effie.
Also, borrowing from another thread, I went laminated glass. The glass area in a stock height T is huge and I believe the laminated has better sound reduction.
Old 04-01-2005, 09:29 PM
fatfenders's Avatar
"I believe the laminated has better sound reduction."
I had not even considered that, but laminated would about have to have the edge. Glass and steel are your enemy when it somes to a quiet interiors. Just don't believe it if you're told you have to live with rattles and road noise becaue you don't.
And there is nothing really wrong with the Home Depot route (Peal and Seal), but you can get heat resistant sound deadeners for awful close to the same price.
Old 04-01-2005, 10:04 PM
True Im sure but when I have the urge to do something I often dont have patience for mail order. With 3 Home Depots within 15 minutes plus 3 WalMarts and others I go the instant gratification route! Heat wasnt the issue as much as noise in the T. The 3/4" plywood floors and firewall kept heat down as well as improving structual rigidity.
Old 04-01-2005, 11:17 PM
fatfenders's Avatar
Carl
Mine is Peal and Seal for the same reason. It was handy. Only place I am certain I will never use it is the trans tunnel, and the firewall. You'd be smelling hot tar forever. Good chance it might even hold on the roof, but as I said, I don't see any reason to apply anything but insulation up there.
I'm gonna buy ten feet of the good stuff and finish the job someday.
Old 04-02-2005, 09:42 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Fish -- sorry to hijack your thread but I've been trying to get ahold of you all week! Your email system (excite) is rejecting all emails not on some list you apparently set up. Please call me at 400-2563.
-- Ross
Old 04-02-2005, 09:59 AM
truckfarmer truckfarmer is offline
truckfarmer is starting off with a positive reputation.
the magazine article mentioned here states that Quiet Ride says you don't have to cover the entire cab for it to be effective. They claim only 30-50% will be enough. If you find that article please read it. I scanned it into my computer if someones a copy. It should also be in their website by now.
Dynamat Björn 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 11-18-2014 04:19 PM
Dynamat in the doors Hotwheelbill 6.0L Power Stroke Diesel 1 03-12-2014 08:09 PM
rubberized undercoating/dynamat whatthencuz 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 09-20-2009 12:56 AM
Dynamat or Baffle? (or both) naiku Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 4 09-21-2005 10:20 PM
Any Dynamat Dealers here? FTE Ken General NON-Automotive Conversation 1 11-02-2001 08:50 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
