Low Speed Drive Train or Brake Whapping
Old 03-27-2005, 04:10 PM
Flaw's Avatar
Flaw
Flaw is offline
Hi, This is my first post here in FTE. Absoutly Wonderful Site. My truck is a 1997 F-150, 5.4L V8, Super Cab, 8 Foot Bed, Lariat, 4x2. Rare Truck I have read in some posts... Well, down to my question. at low speeds up to 25 MPH usually when slowing down with my foot off the accelerator, i can her a *whap whap whap* sound coming from what i think is one of the four tires. (Im glad i could narrow it down for you) It dosn't stop when I press the brake pedal, and dosn't happen all the time. Temperature has no effect on it, happend through winter and still now in the 50's. It dosn't effect anything, braking is fine, all else is fine. Could it be a warped front rotor or rear drum, or possibly a u-joint, or the drive shaft... I have no clue. I know this truck like the back of my hand, do all my own work, but can't figure this one out. Any advice would help. Thanks!
Old 03-27-2005, 05:17 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 03-27-2005, 06:30 PM
peppermrj's Avatar
peppermrj
peppermrj is offline
U joint. Go back and forth between drive and reverse and listen for the clank. MY 2 cents.
Old 03-27-2005, 06:51 PM
kingfish51's Avatar
kingfish51
kingfish51 is offline
I doubt if it is a warped rotor or drum. You would feel this as a pulsation with the brake applied, and your problem happens whether or not the brake is applied. I would agree, the first thing to look at are U-joints.
Old 03-27-2005, 11:53 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
A warped rotor can sometimes cause a noise like that as it forces the caliper back and forth, even when you're not braking. You would have a pulsation when you press the brakes though.
I would also start with checking the U-joints. You may have to remove the driveshaft to tell for sure if they are good. Sometimes they will feel ok but are actually binding.
If they are ok I would swap the tires in an X pattern and try it. I've been fooled by tires a few times lately.
Old 04-01-2005, 12:30 PM
Flaw's Avatar
Flaw
Flaw is offline
That Was It, The U-Joint In The Driveshaft. Thanks So much.
Old 04-01-2005, 02:21 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
Thanks for letting us know what you found
Old 04-01-2005, 04:32 PM
peppermrj's Avatar
peppermrj
Thumbs up
Amen and Happy motoring!
BuddhaKat
1999 to 2016 Super Duty
05-15-2013 12:56 PM
SHO rescue 79
05-15-2012 11:33 AM
OverHeight
06-22-2011 07:19 PM
frederic
Garage & Workshop
04-12-2007 04:08 PM
nickmobile67
58
10-12-2004 05:33 PM
Quick Reply: Low Speed Drive Train or Brake Whapping
