'83 Ranger Electric Choke - Ford Truck Enthusiasts Forums
Old 03-25-2005, 09:18 PM
pwhetton pwhetton is offline
pwhetton is starting off with a positive reputation.
Hey All,
I've recently gotten an 83 ranger 2.0L from a farm. The engine's been swapped out and they did a real butcher's job with the wiring. The carb choke is held open with a bungee cord!! I've applied 12 volts to the choke and it does open after a little while.
If it was hooked up properly, would a constant 12volts be going to this while the engine is running or does some relay cut it off after the engine warms up?
Looking at the wiring diagram that the book says i should have, it shows the electric choke wire going to the back of the alternator and then that wire continues to the ignition control module. Unfortunately i don't seem to have the same connections on my ignition module for this wire. Can i just rig a wire tied to my ignition so that 12 volts is always on the choke or is there a better way?
Thanks!
Dale
Old 03-26-2005, 09:47 AM
Samsonitesamsonite's Avatar
Samsonitesamsonite Samsonitesamsonite is offline
Samsonitesamsonite is starting off with a positive reputation.
got the same question for my 79 2.3
Old 03-26-2005, 05:04 PM
OK, here's what i've found so far. I've seen more wiring diagrams which show the stator connector from the alternator as the contact for driving the choke. I've even found the wire with the connector at the right distance to make the connection. The problem: NO Voltage at the stator connector on the alternator. Seems kind of odd because my battery isn't dying, so i assume my alternator works. Oh weel, i found another 12 v wire that was dangling and was only powered while the key was in the run postion. i hooked that up and i seem to have electric choke working properly now.
dale
Old 03-27-2005, 12:36 PM
Bart99GT Bart99GT is offline
Bart99GT is starting off with a positive reputation.
The electric choke does indeed get its power from the stator wire off the alternator on those engines. Were you checking the voltage while the engine was running or not? There will be zero volts at the stator when the engine is off because the stator voltage is controlled by the voltage regulator.
The electric choke cuts itself off with two bi-metal strips inside the cap. One is sensitive to the heat generated by the electrical current flowing through it, and the other to ambient temperature. When either one opens, it opens the circuit and shuts off the electric choke. By the time either opens the engine should be warmed up enough not to need it any longer.
Truck ignition dropping voltage Mustangking1 1973 - 1979 F-100 & Larger F-Series Trucks 12 10-08-2015 06:09 AM
Stove choke to full auto choke? Mdc9966 1973 - 1979 F-100 & Larger F-Series Trucks 3 09-16-2015 12:20 PM
Holley / Motorcraft 4180c Choke Questions Tkc432 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 06-27-2015 02:00 PM
Choke questions answered. fmc400 1973 - 1979 F-100 & Larger F-Series Trucks 55 07-30-2014 11:11 AM
edelbrock electric choke hotrod351 Fuel Injection, Carburetion & Fuel System 8 03-26-2010 07:26 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1997, 23, 83, adjustment, automatic, choke, diagram, electric, f150, ford, motor, ranger, retun, spring, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
