Diesel #1 Dye Filter? - Ford Truck Enthusiasts Forums
Closed Thread
Old 03-25-2005, 08:44 PM
dogdude2003 dogdude2003 is offline
dogdude2003 is starting off with a positive reputation.
Anyone ever heard of a filter that would eliminate the dye in off road diesel? Example: tank in yard, hose with filter which makes it clear on the way to nozzle, which is then placed in say...a tractor or farm equipment?
I know there was a very large thread on this subject, but I'm not sure anything was mentioned about filtering or eliminating the dye. Did I miss it?
Thanks
Old 03-25-2005, 10:14 PM
foud foud is offline
foud is starting off with a positive reputation.
I would also be interested in this. I run farm fuel and the dye is a problem for the 6.0 liter diesel, or so i have been told. If anyone can come up with a solution, let us know.
Old 03-25-2005, 11:48 PM
jbullfrog's Avatar
jbullfrog jbullfrog is offline
More than just a Handyman
jbullfrog is gaining momentum as a positive member of FTE.
It is illegal to run non taxed farm fuel in a road vehicle. That is why it is dyed. No, there is not a filter to "undye the fuel, that would also be illegal. It is a $100 dollar a gallon problem to get caught with red fuel in the tank of pickup.
Old 03-26-2005, 12:12 AM
Jbullfrog: Give me the code section, making it illegal to remove red dye from #1 diesel.
And did you not read my post? There was no mention of any "road vehicle". I did, however mention tractor and farm equipment. Did you miss that?
In addition, how do you know there is no filter to undye the fuel?
The red dye has been known to clog up equipment and filters in machinery.
Old 03-26-2005, 01:21 AM
jbullfrog's Avatar
Sorry, I wasn't implying you had intentions to do something illegal. Here is information that should be of help.
Problems with dyed fuel are caused by the higher sulfer levels allowed in off road fuel, not the dye itself. Clear fuel has a 5 ppm sulfer content and dyed fuel can be as high as 500 ppm.
On road fuel has a low sulfur content to prevent catalytic converter damage. The sulfur will deactivate the catalyst and lead to soot clogging of the converter core. The seal shrink&swell characteristic of low sulfur fuel is different than the high sulfur fuel also. The process of producing the lower sulfur content raises the Cetane rating of the fuel, but lowers the fuel lubricity. Some engines need the higher Cetane of low sulfur fuel.
You can use undyed fuel and get the tax credited back for off road use.
Old 03-26-2005, 02:15 AM
veselyc veselyc is offline
veselyc is starting off with a positive reputation.
chemicals to remove dye
they do make a chemical that removes the dye. however, dmv tests for this chemical.
Old 03-26-2005, 02:21 AM
With all due respect and with no intention of starting a political debate on the issue...the original topic had to do with filtering out the dye.
AND I might add...
The sulfer level in the diesel has to do with emissions regulations set forth by the EPA and CARB. The dye is to distinguish types of taxable diesel for the IRS.
If red dye is found in an on road vehicle, they test for sulfer level. That's where they distinguish whether or not you are violating emissions regulations and evading tax by using a tax exempt fuel.
Bottom line: no red dye, no test for sulfer. Red dye is for taxes and sulfer is for emissions.
If the Cetane level is high enough...the engine is fine. No cat..no clog.
Old 03-26-2005, 02:27 AM
What is the chemical?
Old 03-26-2005, 03:57 PM
Beachbumcook's Avatar
Beachbumcook Beachbumcook is offline
Got Diesel?
Beachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to all
You guys should just drop it and move on.
Call your local AG fuel supplier that supplies your farm, town, or local station and ask them. Heck, call your state's fuel taxation department and ask them?
Heck, call Ford and tell them you own a farm and wish to run dyed fuel in your 6.0L motor (off-road of couse).
Dogdude, you asked a question and got a reply then "blasted the poor guy". He was trying to help and offer advise... and you "blasted him".
Call your fuel supplier people or any of the major fuel companies and ask them... since I am sure no one here is an expert on this topic and your "blasted" the first guy to respond.
If I could close this thread I would, since it has been discussed many times before here on FTE with no "absolute answer" being given.
Old 03-26-2005, 05:59 PM
I didn't blast anyone. The topic had to do with a filter for the red dye...not the legal aspects of taxes, emissions, cetane levels, et al. I'm sorry if I came off that way. Perhaps the kurt response to me about how illegal it is, thus assuming I'm looking to commit a crime without really reading what I posted, should be equally scrutinized. Or maybe you (beachbum) are still looking to "gotcha" me as like you tried before with the "sportscar" thread. LOL
Nice try. hehe
As far as dropping it, I will if no one knows of a filter for eliminating the red dye...otherwise I will hold off until the chemical is found out for eliminating it or a filter comes to light.
Old 03-26-2005, 06:11 PM
Daryl Hunter's Avatar
Daryl Hunter Daryl Hunter is offline
Daryl Hunter is gaining momentum as a positive member of FTE.
We just got done with another series of contentious threads - we are all tired of that right now.
Be nice.
Going forward for a while, I will lock any thread that has a hint of bickering.
Closed Thread
03 f250 6.0L jtug69 6.0L Power Stroke Diesel 18 05-22-2015 05:40 PM
Oil leak Dye Questions PSDNovice 6.0L Power Stroke Diesel 9 11-07-2014 10:15 PM
Anybody try to dye doorpanels? GM4WALLS 1973 - 1979 F-100 & Larger F-Series Trucks 19 01-31-2014 01:28 PM
Red Dye vs. Green Dye bassproguy07 Bio-diesel, Propane & Alternative Diesel Engine Fuels 30 04-10-2006 10:35 AM
Red dye fuel trace removal? olfordsnstone 6.0L Power Stroke Diesel 6 07-03-2005 05:30 PM
Tags
color, diesel, dye, dyed, dyes, farm, filter, filtering, filters, fuel, illegal, red, remove, remover, removing, road
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
