Which is the correct splash pan?
Old 03-25-2005, 06:58 PM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
I have these two splash pans and both of them are different.
What years does each one go to or are they interchangeable?
Thanks, Ilya
Old 03-25-2005, 07:32 PM
barry's Avatar
barry
barry is offline
I've seen those and several more. The rusty one is like the one I'm using on my 50 F-1.
Barry
50 F-1
Old 03-25-2005, 11:45 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Barry, where do these mount? Were they an option? or aftermarket? or is it just another piece that got tossed from my truck?!?!
Old 03-26-2005, 06:35 AM
barry's Avatar
barry
barry is offline
It's a pain to work on the underside of the engine with it on. It bolts to the frame rails under the radiator, tilting backwards. THere's some 1/4 inch holes in each side of the frame. THere were two styles or sizes, one for the V8 ( pictured) and a narrow one for the 6 cyl. I've parted a few trucks and some of these were gone. Yes, someone probably tossed it a long time ago.
Barry
50 F-1
Old 03-26-2005, 08:34 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Thanks, I've never even seen one. I wonder if the help with airflow at all? I assume that hole is for the draft tube?
Are you selling either of these, Panelman?
Old 03-26-2005, 08:55 PM
51PanelMan's Avatar
51PanelMan
I don't know yet.
I assume that both of these are for the flathead engines. I bought both to use on my Panels. However, if both are for flatheads, then I won't have any use for them, because my '52 will receive an OHV 6 cylinder and my '51 will get a 350 SBC.
Barry, are the pans for the flathead engines only?
Thanks, Ilya
Old 03-26-2005, 09:06 PM
hamz52's Avatar
hamz52
hamz52 is offline
Ilya
I may be interested in the one for the 52. I know that they are probably more trouble than they are worth but thats the way Henry made it.
Ham
Old 03-26-2005, 09:36 PM
51PanelMan's Avatar
51PanelMan
Originally Posted by hamz52
Ilya
Ham
If it's not for the OHV and only for the flathead, then I won't have any use for it.
This is what I am trying to find out.
Ilya
Old 03-26-2005, 10:05 PM
Overkill-F1's Avatar
Overkill-F1
Overkill-F1 is offline
The painted one on the left is like the one from my '52 F1, 239 flathead V8. The hole looks odd in the photo, mine is a perfect circle. Has that one been modified? I think that the panel would keep water/mud from splashing into the front of the motor from the front wheels. ...Terry
Old 03-26-2005, 10:58 PM
51PanelMan's Avatar
51PanelMan
My guess is that the downtube didn't fit properly into the whole, so it was modified to fit.
Ilya
Old 03-27-2005, 12:06 AM
Overkill-F1
The panel might help with the draft tube operation. It would at least keep the air flowing from the fan and rad from interferring with the air flow pass the bottom end of the draft tube. ...Terry
Old 03-27-2005, 07:17 AM
barry's Avatar
barry
barry is offline
The 52 with a OHV had a narrow one that went across inn the same manner. It was about 4-6 inches wide and the width of the frame. It was 3-4 inches deep. Kinda like a wind deflector to me. I've only parted one 52 and it had this one on it. There's at least 3 different ones for the flatty that I've seen. You show 2 of them and I've had a third one without the hole. All came off of V8's.
Barry
51PanelMan
13
08-19-2010 08:56 AM
51PanelMan
03-11-2007 11:38 PM
51PanelMan
13
10-09-2006 09:25 AM
51PanelMan
08-10-2006 01:47 PM
51PanelMan
03-23-2005 07:41 PM
Quick Reply: Which is the correct splash pan?
