1981 F250 351W fuel pump install problems - Ford Truck Enthusiasts Forums
Old 03-18-2001, 03:42 PM
taoduck taoduck is offline
taoduck is starting off with a positive reputation.
I hope someone can give us some feedback...
We are replacing the fuel pump on the above mentioned truck, and having no end of problems, mostly due to the extremely difficult positioning of the (mechanical) pump on the block.
We want to make sure we are positioning the rocker arm correctly, but can't seem to get any feel for the proper place. We are rotating the camshaft now and again to try and get the arm inside so that it runs on the underside of the eccentric, but it seems that no matter where we rotate the engine, the arm won't go in enough to allow us to get the flange of the pump in position to bolt it to the block. The best we can do is to have the flange about 1/2+" below where it should be, but in contact w/ the block, and the lower part of the flange a good inch or so away from the block. But the arm does seem to be under "something". HELP!!!
We need this truck operational!! Any feedback would be greatly appreciated!!
Thanks... Tduck
Old 03-18-2001, 06:30 PM
rsbeadle rsbeadle is offline
rsbeadle is starting off with a positive reputation.
It may be necessary to remove the power steering pump to be able to get a good view of the install area, but the fuel pump can usually be installed without pulling the p.s. pump. It will be necessary to push up on the fuel pump pretty hard to push down the fuel pump actuator rod enough to line up the bolt holes with the engine. It is always pretty hard to push the fuel pump up, but try rotating the engine in quarter turn incraments until it will go in the farthest, then install the pump with the rod going in so that you are sure the rod goes below the cam eccentric and force it up until you can get the bolts in. Most times the fuel pump rod won't be physically able to go over the cam eccentric so you really can't get it in that way. The rod has to keep constant pressure on the eccentric so that it doesn't make a noise, so it's always going to be sprung.
Old 03-18-2001, 07:09 PM
figaro56 figaro56 is offline
figaro56 is starting off with a positive reputation.
Old 08-28-2012, 07:53 AM
SCarp SCarp is offline
SCarp is starting off with a positive reputation.
I am looking for some advice on replacing the eccentric fuel pump on a 1980 351W. I have had some folks inform me that the eccentric is two pieces and some say only one. Can someone clarify this for me. The motor is actually in a 1980 MasterCraft ski boat. The short block is all the same as the trucks. The timing chain cover is cast ad becomes the water pump. Please advise.
SC
Old 08-28-2012, 08:04 AM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Welcome to FTE.
I think your answers are here:
http://www.ford-trucks.com/forums/11...-question.html
Old 08-28-2012, 07:27 PM
81ChopTop's Avatar
81ChopTop 81ChopTop is offline
81ChopTop has a very good reputation on FTE.81ChopTop has a very good reputation on FTE.81ChopTop has a very good reputation on FTE.
To the OP:
A little trick I do is to install some 3/8" x 2" long studs (set screws) in the timing cover. Install gasket and just push on the fuel pump, then put on some serrated nuts. Works great and no alignment problems or fighting the arm pressure to get bolts started. It will be right every time.
http://www.fastenal.com/web/products...l.ex?sku=25547
Pump not drawing fuel Teal77F250 Fuel Injection, Carburetion & Fuel System 2 01-09-2017 09:57 AM
Wiper Arms - Getting the "Correct" One Occidental 1967 - 1972 F-100 & Larger F-Series Trucks 9 10-19-2016 06:45 AM
MII Front end coil spring question Tyler S 1948 - 1956 F1, F100 & Larger F-Series Trucks 43 02-25-2014 03:05 PM
09/99 DIY up pipes welded flange w/donuts and vibrant bellow Michael Mehegan 1999 - 2003 7.3L Power Stroke Diesel 2 02-01-2014 05:37 AM
1990 F150 302 Wont Start calguy 1987 - 1996 F150 & Larger F-Series Trucks 21 12-06-2011 07:19 PM
Tags
1981, 351, 351w, f100, f250, ford, fuel, install, installation, location, pump, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
