Go Back   Ford Truck Enthusiasts Forums > Misc. > Brakes, Steering, Suspension, Tires, & Wheels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Brakes, Steering, Suspension, Tires, & Wheels Click Here
Is F-150 Still King?
  #1 (permalink)
Old 03-23-2005, 12:19 PM
MemOrex MemOrex is offline
MemOrex is starting off with a positive reputation.
Installing Coil Spring Spacers
I got some rubber spacers for my saggin front end. Where is a good spot to jack up the truck to take all tension off the springs?
  #2 (permalink)
Old 03-23-2005, 12:23 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE. MustangGT221 has a good reputation on FTE. MustangGT221 has a good reputation on FTE.
The best place is from the frame...
__________________
Justin-FTE Moderator
95' F-150 XLT 4x4, 393ci stroker, 5 spd, 6" lift/35s
04' Explorer Limited 4.6L
94' Cobra - 1 of 123 made, only 30k miles
87-96 Forum
  #3 (permalink)
Old 12-30-2005, 12:24 AM
omni's Avatar
omni omni is offline
omni is starting off with a positive reputation.
memorex can you tell me how those coil spring spacers worked out, I'm thinking of a set, was going to go with leveling springs but nobody could guarantee me a full 2", so I was entertaining the 2" spacers thanks
__________________
1994 f150 XLT 4x4 5.8 E40D
1987 f150 XL 4x4 5.0 AOD
1978 Bronco XLT 400 C6
  #4 (permalink)
Old 12-31-2005, 02:55 AM
bob arrington bob arrington is offline
bob arrington is new and has a neutral reputation at this point.
If you have OE' sagged springs' on the front you can replace them with the 'heavy duty' version of them and obtain the same two inch raise. Runs about ninty bucks and you dont have to worry about them bouncing out when you hit a bump.
worked great on my one ton. bob
  #5 (permalink)
Old 12-31-2005, 03:31 AM
Yes, go with aftermarket or heavy duty springs. It might cost more, but they are more reliable and don't ride as rough as just spacing out. I took the spacers off :-\
  #6 (permalink)
Old 06-24-2009, 11:28 PM
Unitedsc16 Unitedsc16 is offline
Unitedsc16 is starting off with a positive reputation.
I just got some coil boosters and I'm not really sure how to install them. I just want to lift the front end, this is the cheapest way I found, are there any more cheap sufficient ways to lift the truck??
  #7 (permalink)
Old 07-01-2009, 03:06 PM
BuickBrian's Avatar
BuickBrian BuickBrian is offline
BuickBrian is starting off with a positive reputation.
What kind of alignment issues did you guys run into when putting in the 1.5-2" leveling springs in the front? I am looking to do this on my 1988 F150 4x4. Did you have to change camber bushings, and if so, how many degrees did you have to change by?
  #8 (permalink)
Old 07-09-2009, 10:51 PM
TC-Countryboy's Avatar
TC-Countryboy TC-Countryboy is offline
1995 Ford F-250
TC-Countryboy is starting off with a positive reputation.
Hello,
Noticed the thread, and thought I would jump in. Back many years ago, I broke a spring, on a 84 F150 4x4, so I figured I would go ahead and level the front end out by ordering the heaviest springs I could find from a local parts store. Well it leveled it out, but the top of the tires were cambered out so far, it couldn't be brought back into spec. Didn't want to mess with putting the 1.5 - 2" drop brackets in, and didn't want to go throught tires, so I put a set of standard springs back in. I still have the springs, if anyone is interested and want to give it a try.
TC
  #9 (permalink)
Old 07-12-2009, 07:49 PM
nathan19 nathan19 is offline
nathan19 is starting off with a positive reputation.
Quote:
This, i would definitely recommend heavy duty springs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
