315/75/16/ on f350 daully - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 03-22-2005, 11:38 AM
markpruitt63 markpruitt63 is offline
markpruitt63 is starting off with a positive reputation.
Thumbs up 315/75/16/ on f350 daully
i have a 02 f350 daully i have seen a few trucks like mine with 315/75/16 i was wondering what size wheel spacer i need in the rear to keep the tires from rubbing each other.any body with with experience.
Old 03-22-2005, 01:18 PM
Rowdyone Rowdyone is offline
Rowdyone is new and has a neutral reputation at this point.
I have not done this, but I am quite sure you would need something along the lines of 4.5-5 inches to get the tires away from each other far enough so as not to have heat build up from them. The tires bulge past a regular rim by 2", so if you double that it would have you at 4" and that would have the tires on each other. You may have to see about finding a different off set for the bud wheels to get that size on the back. Good luck
Old 03-22-2005, 01:38 PM
i figured it up as 315 is 80 mm wider than a 235 , so 100mm is almost 4 inches, with the narrow rims like what is on i didnt think the tire would swell out in the side wall like the 235, so i was figuring 4 inch should clear, but i dont know.
Old 03-25-2005, 01:37 AM
shoobear's Avatar
shoobear shoobear is offline
shoobear is starting off with a positive reputation.
Hey 4" will work but u will have alot of space between your rear duals. U only need a 2" spacer to run 315/75/16 (on each side eh!)
hope this helps,
cheers
shawn
Old 03-27-2005, 11:36 PM
hey thanks man if you say 2 will work i havent done it and you sound for shure so i will take your word.
Old 04-12-2005, 09:08 PM
shoobear's Avatar
hey, just bolted up my 2" spacers about a week ago. i am running 315/75/16 mtrs and there is lots of room between the rear duals.
cheers
shawn
Old 04-12-2005, 10:05 PM
RedTaurus94's Avatar
RedTaurus94 RedTaurus94 is offline
RedTaurus94 is gaining momentum as a positive member of FTE.
shoobear....do you think there is any way you could take a picture of that set-up and post it on here? Seems a lot of folks have asked about it lately and i know I would like to see what it looks like.........
Old 04-12-2005, 10:53 PM
dunedog2001 dunedog2001 is offline
dunedog2001 is starting off with a positive reputation.
shoobear, are you running those 315 on stock 6", or something else.
http://www.wheeladapter.com/default.asp
here is where i found my spacers
phil
Old 04-12-2005, 11:10 PM
shoobear's Avatar
hey the only rim that i know of for the dually is a 6", the mtrs are suppost to be on a (I think) a 8" rim, but i run them on my stock rim. I know of a few guys that use this size on stock rims. They look good!
Hey i cant post pics, not sure why, if u want a pic of the my dually with the spacers installed send me a email. The spacers from ebay are a lower quality tha the ones from wheel adapters.com, i used the spacers from wheeladapters.com and when u install them u have to put the first wheel on, slide out the axle, put on the spacer, then slide the axle back in, and bolt on the outside wheel. Takes a few minutes more on each side but the spacer is made with a little taper on the inside dia and fits really good. The spacers ARE hub centric, the ebay spacers are not hub centric, they use a different wheel stud than your stock lug nuts and will have to buy nuts. The money u save on the spacers on ebay will go towards new wheel nuts. So hope this helps.
cheers
Old 04-12-2005, 11:17 PM
thanks for the info, what size lift are you running ?
phil
Old 04-12-2005, 11:23 PM
shoobear's Avatar
im running a 6" all spring lift, the rear springs are 5", its a donahoe edge lift,
Old 04-14-2005, 10:02 AM
'96 F-250's Avatar
'96 F-250 '96 F-250 is offline
'96 F-250 is starting off with a positive reputation.
305/50-20 is mounted on my f-250 tomorrow....pics will come!
Old 05-08-2005, 12:08 AM
shoobear's Avatar
hey i got some pics of my truck but cant post em. email me i u want a pic of the rear duals with the 2" spacer.
cheers
Old 05-08-2005, 06:27 PM
'96 F-250's Avatar
Old 03-25-2006, 12:36 AM
shoobear's Avatar
Hey markpruitt63,
did u end up putting the 315's on your dually? Im going to get some 17" dually wheels(when i can find some) for my next set of 37" mtrs. The mtrs work great in the snow,mud and hwy.
cheers
Wtb split / daully. Wheels 1969 f-350 5up3rduty WTB - Parts & other 2 10-10-2016 01:56 PM
Tire and wheel help casey88307 1967 - 1972 F-100 & Larger F-Series Trucks 0 03-21-2016 07:51 PM
running 315/75/16 tires 00v10power 1999 to 2016 Super Duty 6 02-16-2010 10:25 AM
Speedo correction MustangMatt96GT 1994.5 - 1997 7.3L Power Stroke Diesel 5 11-18-2009 01:37 PM
running 315/75/16s with 4.56 gears Rcmgiasson Offroad & 4x4 6 10-19-2005 08:17 PM
Tags
16, 2, 315, 31575, 3157516, 315s, 75, daully, dually, f350, inch, spacer, spacers, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
