Which is louder
Old 03-21-2005, 11:33 AM
1993_f150's Avatar
1993_f150
1993_f150 is offline
Which is louder
I have a 93 f150 wi th the 2 cats on my exhaust, and it isnt quite loud enough. I was thinking about just cutting the second cat off but then i was wondering if it would be better to just take both off and put a high flow cat on instead. Which one would be louder the high flow cat or cutting of the second original cat.
Thanks for your help
Old 03-21-2005, 12:30 PM
Firefighter8-1's Avatar
Firefighter8-1
Firefighter8-1 is offline
not sure what engine ur running, but on my 302 i had a catback flowmaster 40 installed and it wasnt quite loud enough. i then cut off both cats and installed 1 high flow catco and the sound now is just where i want it. it has a nice deep idle and on takeoff it just roars. my family and friends say they can hear me coming from a few blocks away so i musta did something right. hope this helps
Old 03-21-2005, 03:07 PM
MemOrex's Avatar
MemOrex
MemOrex is offline
I cut the second cat off on my 93. It got loud. I plan on doing true duals tho.
Old 03-21-2005, 07:44 PM
RICE H8R's Avatar
RICE H8R
RICE H8R is offline
On my F150 the second cat was gone when I got it, but I swapped out the muffler for a FM 40 si/do on it. It's not too quiet, but not overly loud either. You can hear it coming from a few blocks away. It could be a little louder for my taste, but it's not bad. I just wish it had a little more crackle.
Old 03-21-2005, 11:03 PM
MemOrex's Avatar
MemOrex
MemOrex is offline
Forgot to mention, I only have the first cat, and no muffler. Has a 'burbly' sound I just love .
Old 03-21-2005, 11:29 PM
1993_f150's Avatar
1993_f150
By the way i have a 302 with straight pipes and dualed out after the cats. but i f i was to just cut off the cat, can i just put on an exhaust clamp (do they leak) because i cant weld good at all.
Old 03-21-2005, 11:36 PM
MemOrex's Avatar
MemOrex
MemOrex is offline
It needs to be welded since the pipe going to the cat is 3"....unless your straight pipes are 3". (probably not).
Old 03-22-2005, 12:12 PM
hillbilly316's Avatar
hillbilly316
hillbilly316 is offline
just curious but if you cut off the second cat or take off both originals and replace it with a single highflow would the truck still pass emissions ?
Because i have a 96 150 with single to dual catback exhaust, and it sounds ok but i would like it to be louder.
Old 03-22-2005, 12:50 PM
kens64's Avatar
kens64
kens64 is offline
Particle-wise, yes, it will pass.
It will fail a visual inspection quicker than a Honda in a tractor pull. It came from the factory with 2, there had better be 2 there when the emissions guys checks it.
Old 03-22-2005, 03:16 PM
MemOrex's Avatar
MemOrex
MemOrex is offline
Maybe you can lie and tell them the factory cats failed...lol .
Old 03-22-2005, 03:53 PM
Saurian's Avatar
Saurian
Saurian is offline
They still will want two underneath there. Freakin green-team.
No cat's..just a pair of glasspacks to do my singing. I just bought a CD player and honestly..I don't know why. I just love hearing my truck. Course...gas prices....*whine*
Old 03-22-2005, 07:18 PM
MemOrex's Avatar
MemOrex
MemOrex is offline
They still want 2 even though the one Hi-Flow cat passes?? That is so weak, man....
Guess you can gut one and put the Hi-Flow on there...lol
blue924.9
10-14-2015 05:04 PM
Wisconsinford
04-09-2013 07:59 PM
Prplmnsterf150
Exhaust Systems
03-03-2005 08:26 PM
homer4.2
3.8 & 4.2L V6
11-02-2004 01:05 AM
87black150
Exhaust Systems
08-10-2003 04:43 AM
Quick Reply: Which is louder
