Coolant System By-Pass Kit - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 03-20-2005, 10:01 PM
SHOpar's Avatar
SHOpar SHOpar is offline
SHOpar is gaining momentum as a positive member of FTE.
Hey Everyone,
I posted a message about six months ago about a cooling system problem with my '93 3.0 AT 2WD Ranger. Basically, when it warms up I get a loud knocking noise from the thermostat housing area. It seems like there is air trapped in the cooling system, but no matter what I have tried to do to get it out, I still have the same problem.
I talked with a shop last week about this problem, and one of the mechanics working there is an ex-Ford tech, and he said there was a TSB out about this issue. It is TSB 96-21-12, and it describes the exact problem I am having. Apparently to fix it, you have to install a cooling system by-pass kit (p/n F47Z-8522-F), which includes a coolant by-pass kit, replacement lower radiator hose, and elbow-hot water heater connection. It lists for almost $200, and I can probably get it online for about $150.
Before I spend the money, I was wondering if anyone else has experienced this same problem and if the kit solved it. Also, I am trying to figure out exactly what this kit does to see if I can replicate if for cheaper.
Thanks in advance!
Old 03-21-2005, 07:23 AM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
3.0L Cooling System Thump - Temperature Gauge Fluctuation
I don’t have any personal experience with the kit, but FWIW there is a similar type of kit for the 4.0L which addresses the same concern (steam formation in cooling system).
Here is the full TSB covering the 3.0L referenced by the shop:
Quote:
Article No. 96-21-12
LIGHT TRUCK: 1991-95 RANGER 1995 AEROSTAR
This TSB is being republished in its entirety to include the 1995 model year and to add Aerostar to the list of affected vehicles.
ISSUE:
A "knocking/thumping" noise may be audible in the passenger compartment on some vehicles. This noise is most pronounced with the engine at normal operating temperature. The noise is caused by steam formation in the cooling system. The noise is then transmitted through the heater hoses and heater core.
ACTION:
Install a Coolant By-Pass Kit. This increases coolant flow which reduces steam formation. Refer to the following Diagnostic and Service Procedure for details.
DIAGNOSTIC AND SERVICE PROCEDURE
1. Check that base timing is at 10* BTDC with SPOUT disconnected.
2. Check for excessive exhaust system restrictions. A restricted exhaust could elevate cooling system temperatures.
3. If dash-mounted cooling temperature gauge fluctuates, check that gauge and sending unit are functioning properly.
4. Check for restrictions or kinks in the radiator or heater hoses.
5. Pressure check cooling system for leaks.
6. Confirm proper Engine Coolant Temperature (ECT) sensor signal to EEC-IV processor. Refer to TSB Article 93-24-8 (Cooling System - Thermostat Diagnosis) for tool and procedure to check thermostat.
7. Check for correct 50/50 coolant mix. Verify that freezing point is -37̊C (±-3*C) or -35*F (±5*F).
8. For 1991-93 Rangers, install a 110 kPa (16 psi) Radiator Cap (F4TZ-8100-B). NOTE: These model year vehicles originally came with a 90 kPa (13 psi) radiator cap.
9. If concern still exists, install service Coolant By-Pass Kit and verify that concern has been resolved. Refer to the Application Chart:
PART NUMBER / PART NAME
F57Z-8522-AA / By-Pass Kit (1995 Ranger)
F59Z-8522-CA / By-Pass Kit (1995 Aerostar)
F47Z-8522-A / By-Pass Kit (1991 Ranger With Automatic Transmission)
F47Z-8522-B / By-Pass Kit (1991 Ranger With Manual Transmission)
F47Z-8522-C / By-Pass Kit (1992 Ranger With Automatic Transmission)
F47Z-8522-D / By-Pass Kit (1992 Ranger With Manual Transmission)
F47Z-8522-E / By-Pass Kit (1993-94 Ranger With Automatic Transmission)
F47Z-8522-F / By-Pass Kit (1993-94 Ranger With Manual Transmission)
F4TZ-8100-B / Radiator Cap
OTHER APPLICABLE ARTICLES:
93-24-8
SUPERSEDES:
95-12-8
Old 03-23-2005, 08:05 PM
SHOpar's Avatar
Thanks for the response Rockledge!
I will probably just bite the bullet, order the kit, and hope it fixes the problem. The TSB describes my exact problem, so I'd think the kit will fix it.
I notice you have a 94 SHO MTX - how do you like it? I've had my 95 MTX for five years now and love it. Even with 120K on the clock, it runs like new and will still beat a majority of the cars on the road.
Old 03-23-2005, 08:19 PM
Rockledge's Avatar
I've had my SHO less than 2 years, picked it up cheap and have whipped it into good shape (145K). Currently it's running tip top. I don't drive it much in the winter but I took it for a rip just last weekend and boy did it feel good.
As a matter of fact I was recently tooting my SHO's horn in this thread:
http://www.ford-trucks.com/forums/sh...d.php?t=330601
I checked out yours, it looks like it's in great shape, and your description of the SHO along side the pics is a nice touch, especially for those people who aren't that familiar with it.
Good luck with the by-pass kit, keep us posted on the results.
Old 12-26-2013, 12:53 PM
GeneL56 GeneL56 is offline
GeneL56 is starting off with a positive reputation.
Thumping from cooling system
91 ranger v6, 4.0L, had the same problem for years. new hoses, new thermostat did not solve the problem. temp gauge works fine. just saw this posting a few days ago. tried item #8 on the above TSB: replaced 13lb cap with 16lb cap (ford motorcraft RS-90). The cap switch did dampen the thumping sound somewhat but I still have the problem. Don't want to spend $240 to buy the coolant by-pass kit. And besides, I have lived with "Thumper" for 20 years--he is like an old friend who lives in my glovebox.
Thanks for posting the bulletin!
Old 03-16-2014, 02:05 PM
Jon Ford Jon Ford is offline
Jon Ford is starting off with a positive reputation.
Coolant Pulse
OK people, so now that I have the pulse problem, where can I get A water pump by-pass kit. I'm told by Ford, that the PN#F47Z-8522-E is no longer available. Auto Parts stores have no idea about the kit.Please Help. Jon Ford
Old 03-16-2014, 03:38 PM
Coolant system recovery kit
This place had one 3 months ago. Dunno if they still do.
Bob Allen Ford Parts
9239 Metcalf Ave
Overland Park, Ks. 66212
Cell # 913-707-0054
Parts # 913-381-2999
Fax # 913-383-2947
Wanted $292 plus shipping
Part #: F47Z-8522-A
Obviously, please verify all this stuff, don't take my humble word for it.
Old 03-16-2014, 04:09 PM
Thank you for the info SHOfar. I'll give it a shot.Jon Ford
Old 03-16-2014, 04:11 PM
Hank85713 Hank85713 is offline
Hank85713 is gaining momentum as a positive member of FTE.
go to NAPA, they have the head and filters for the coolant system to install. Not very hard to do this is something that is discussed on the diesel sites often. They can be purchased from some diesel dealers for AM parts. I made my own via the napa route. Dont know about changing the lower rad hose, all that is required for a diesel is to tap into heater hose, and run return line to coolant bottle. Unless there is something different about the ranger one of these should work.
Old 03-16-2014, 04:12 PM
kit
actually it was me, GeneL56, who replied to you, but you can blame SHOpar if anything goes wrong.
All This Coolant Filter Talk Has Me Thinking BigGreenEx 6.0L Power Stroke Diesel 12 08-02-2016 08:55 PM
4.0L Temperature Gauge Fluctuation / Thumping in Cooling System Rockledge Ranger & B-Series 13 03-12-2016 10:52 AM
Oil By-Pass Kit BIGWORM936 1999 - 2003 7.3L Power Stroke Diesel 47 01-20-2016 07:00 PM
Who runs oil bypass filters? 2500ak Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 19 10-30-2013 02:10 PM
By-Pass Engine oil & Transmission Fluid - Help in selection jwplunkett 1999 to 2016 Super Duty 20 08-02-2010 10:54 PM
Tags
1992, 1995, 1999, 40l, 95128, 97, bypass, coolant, copy, ford, instructions, kit, pass, ranger, tsb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
