Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-20-2005, 09:58 AM
Mikeleew Mikeleew is offline
Garage is empty, add now
Mikeleew is starting off with a positive reputation.
Still dealing with a fresh gas smell
Will someone please describe for me the proper routing of the vent tube for my 65 Econoline? It is currently coming out of the top of the tank, through the frame, up into the back quarter where is then loops back down and is forced into a hole in the frame. I still have no leaks.
Thanks,
Michael.
  #2 (permalink)
Old 03-21-2005, 08:21 AM
66gpw's Avatar
66gpw 66gpw is offline
66gpw has a good reputation on FTE.66gpw has a good reputation on FTE.
It sounds like your venting tube is running in the right area.
Is the problem that you are getting a gas smell. Am I right. You then may have holes corroded in the pipes. I had to fix mine and what I used was just some rubber hose connected to the pipes at both ends. There should not be any gas running through this pipe as it is to vent and keep the pressure equal in the tank.
Is the pipes plugged, thus not allowing proper venting. See if you can blow air back into the tank.
Make sure you have no gas line leaks along the route to the engine. You checked the lines at the fuel pumps and carb. That could cause the smell to enter the cargo area of your van.
First make sure your lines are not plugged or corroded causing the smell to come inside.
  #3 (permalink)
Old 03-21-2005, 03:37 PM
Smile What Pipe?
What pipe are you talking about? Is there a pipe in the frame that the vent tube is plugging into? I believe my new vent tube goes high enough that no liquid is making it to the end. I have no visable gas on the ground that I can see.
I will be replacing the pump, fuel lines (hard and soft), and putting on an edlebrock intake with 4 barrel carb in the next week or so. I will also be installing a new HEI distributer and gas shocks. Any advice before I start all of this?
Thanks,
Michael.
Tags
1967, econoline, f100, ford, fuel, gas, odor, smell, truck, van, vents
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
