manual 5 speed v-6 4.2l drain&fill plugs
Sam,
The drain and fill plugs are on the driver's side of the transmission. I believe they are both labeled (cast into the housing).
Remove the fill plug first, then the drain plug.
Here is some more info:
https://www.ford-trucks.com/forums/s...d.php?t=204530
Mercon ATF is the OEM recommended fill.
