Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 03-16-2005, 11:09 PM
racer956 racer956 is offline
Garage is empty, add now
racer956 is starting off with a positive reputation.
chip or propane
I am planning on spending some money on my truck soon and I am looking at a chip (tuner) or propane injection in your opinion what would you choose if money wasn't an option and how safe is propane to run.
__________________
2000 F-350, LongBed, C/C
k&n intake ***. 10k mod leveling kit
35 inch open country wrapped around ultra beadlocks
  #2 (permalink)
Old 03-16-2005, 11:12 PM
mjwhip2 mjwhip2 is offline
mjwhip2 is starting off with a positive reputation.
If money isn't an option then I'd get both. But if I had to choose I'd go with the chip. Without one I don't know the actual improvement of propane alone. Quadzilla is probably the resident expert here on propane injection.
What have you done to your truck already? I'm guessing you have already gotten gauges, intake, and exhaust, right?
__________________
Mike W.
'12 F150 FX4 5.0 Shortbed SCrew
'07 Fusion SEL
  #3 (permalink)
Old 03-17-2005, 06:13 AM
Quadzilla's Avatar
Quadzilla Quadzilla is online now
Quadzilla is gaining momentum as a positive member of FTE.Quadzilla is gaining momentum as a positive member of FTE.
Choosing between a chip and propane? I could give a better answer if I knew a little more about your truck. For example, is it an automatic, or a stick? Are you happy with how it runs now, but merely want more power, or are them some characteristics you'd like to change? For example, shift points on an automatic.
If you're happy with everything else, but merely want more power, then propane can/will give you more power than a chip. As was asked earlier, do you already have the ground work done, by getting a downpipe and exhaust, gauges, and intake?
__________________
When you're walking away from your truck, do you turn around just to look at it? Yeah, so do I. ☺
'13 F-250 Platinum CC SB 4X4 Powerstroke.
  #4 (permalink)
Old 03-17-2005, 08:16 AM
palajoe palajoe is offline
palajoe is starting off with a positive reputation.
MJWHIP,
Way off the topic here, but I like the rear bumper on your truck, who makes that?
Thanks,
Joe
__________________
97 F250 PSD CC 4x4 Tymar; 3" DP; 4" exhaust; 5" tip; CAT delete; pyro, boost and tranny guages; gutted EBPV; XM Roady 2; Electronic compass & ext. temp
  #5 (permalink)
Old 03-17-2005, 08:50 AM
superrangerman2002 superrangerman2002 is offline
superrangerman2002 is gaining momentum as a positive member of FTE.
I'd go with a tuner first. I would also choose a tuner that allows you to have modified tunes downloaded from the internet for when you decide to go with propane. This sure beats having to send your tuner in!
The Predator is the only one that I know of that performs these functions.
__________________
'12 F250 Superduty CC 4x4 6.7L PSD
  #6 (permalink)
Old 03-17-2005, 01:04 PM
Quote:
Originally Posted by palajoe
MJWHIP,
Thanks,
Joe
It's just a Luverne 8" drop. Glad you like
__________________
Mike W.
'07 Fusion SEL
  #7 (permalink)
Old 03-17-2005, 02:35 PM
Quadzilla's Avatar
For the sake of convenience, a tuner might be the way to go. But, for maximum performance, you can't beat a custom programmed flip chip.
__________________
  #8 (permalink)
Old 03-21-2005, 09:17 PM
the details
well I have a 2000 f-350 six speed, gauges, k&n intake and the whicked wheel. I will be going with a 5 inch exhaust and a four inch down pipe. Looking at the computer controlled propane injection from msd. Planning on roasting the wheels off mustangs, firebirds, prep, jock, ferternity cars ect. you know the boys with there cute cars that think they are so hot **** ha thay got nothing on a truck and i want to prove it.
__________________
  #9 (permalink)
Old 03-21-2005, 11:22 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Uhhmmm Racer dont want to burst your bubble but yourstill gonna be slower off the line than a gasser. Most propane systems work off of boost and untill you get the turbo spun up to the trigger point your just another PSD.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
Tags
chip, ford, injection, propane, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
