how does the aux shaft line up? - Ford Truck Enthusiasts Forums
Old 03-16-2005, 08:06 PM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
i got the engine at tdc and the ccam iswhere it is supposed to be, but where do i point the marker for the aux. shaft. it is on an 1987 2.3 5 gear ranger
Old 03-18-2005, 06:43 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
The aux shaft doesn't care. The distributor rotor does. There is a .doc file listed on the FAQ at the top of this section with very detailed timing belt replacement.
Basically. put the cam to where the triangle is lined up with the middle pointer. Put the damper at TDC(before removing belt cover.. Heh). Put the aux shaft where the dist rotor points to #1 plug wire.
Install the belt, and let the tensioner spring loose. Tighten tensioner hold-down. Rotate engine 2X in normal direction BY HAND. Check both TDC & Cam pointers and dist position.
tom
aux fuel tank dimensions abyars111 1967 - 1972 F-100 & Larger F-Series Trucks 15 09-28-2013 04:16 PM
Sirius using Aux input cocot Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 2 03-24-2011 06:12 PM
factory AUX port not working GwarForAll1021 2004 - 2008 F150 0 10-26-2010 08:37 PM
aux button tomsuperduty 1999 to 2016 Super Duty 13 12-28-2008 03:19 AM
aux overdrive theguy_88 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-07-2005 01:40 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1977, 20, 23, auxilary, auxiliary, center, dead, f250, ford, line, marker, ranger, shaft, shafts, top
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
