Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 05-12-2001, 03:29 PM
Pastmaster Pastmaster is offline
Pastmaster is starting off with a positive reputation.
E40d Vs. 4R70W Comparison
Guys, I want to compare these two transmissions. I know that the 4r70W is a electronic version of the AOD.
Does anyone know the gear ratios of:
C-6
AOD
E40d
4r70W
New 4r100
How do they compare?
I understand that after 1995, the E4od was no longer available with the 5.0L and 4.9L I6 motors.
__________________
1993 F-150 2wd 302
1996 F-250 2wd 460
  #2 (permalink)
Old 05-12-2001, 06:57 PM
StrangeRanger StrangeRanger is offline
StrangeRanger is starting off with a positive reputation.
The E4OD and the 4R100 are the same tranny just different designations. The AOD-E is the electronic version of the AOD. Some models came with wider gear ratios. This was later standardized and the transmission has subsequently been renamed the 4R70W. The E4OD was available on the 4.9 and the 5.0 through 1996. The 4.9 and 5.0 were then discontinued, the trannies live on under the new designations.
E4OD ratios are 2.71/1.53/1.00/0.71
4R70W ratios are 2.84/1.55/1.00/.70
older AOD-E ratios are 2.40/1.47/1.00/0.70
I believe AOD ratios were the same for the first 3 then 0.67 for the OD.
Don't know for sure about C4 and C6 ratios but they should be very close to 2.50/1.50/1.00, most 3 speeds were.
__________________
1996 F150 XLT 2WD 4.9 E4OD.
  #3 (permalink)
Old 05-13-2001, 07:50 PM
SR to the rescue again. Thanks! The main reason I thought that the E4OD wasn't offered is because my 96 commercial brochure states that it's not available. I don't know for sure myself.
I appreciate it!
__________________
1993 F-150 2wd 302
1996 F-250 2wd 460
  #4 (permalink)
Old 05-13-2001, 11:33 PM
sweet82 sweet82 is offline
sweet82 is starting off with a positive reputation.
__________________
Rod
64F100 292 auto
69F100 360 3speed
82F100 300 4speed
Tags
1996 , 1997 , 2wd , 4r100 , 4r70 , 4r70w , 4r70we40d , 96 , e40d , e4od , f150 , ford , gear , ratio , ratios , transmision , transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
