Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1967 - 1972 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1967 - 1972 F-100 & Larger F-Series Trucks Discuss the Bumpsides Ford Truck SPONSORED BY:
  #1 (permalink)
Old 03-15-2005, 06:30 PM
cleanLX cleanLX is offline
Garage is empty, add now
cleanLX is starting off with a positive reputation.
C6, rear gear change, speedo gear ?
anyone one know what speedo gear I need when going from 3.54's to 3.73's?
stock 8.75*16.5 tires.
__________________
Mike H.
1969 F250
1992 5.0 lx coupe.
  #2 (permalink)
Old 03-16-2005, 06:37 AM
jowilker's Avatar
jowilker jowilker is offline
1966 Ford F-100
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
jowilker jowilker
Pull the speedo cable out of the tranny, and count the number of teeth on the gear or look for something like 16T (the number of teeth) on the end. I think you will need a one number (tooth) higher for a .25 different ratio change.
John
  #3 (permalink)
Old 03-16-2005, 08:09 AM
dbossman dbossman is offline
dbossman is starting off with a positive reputation.
check out these links
These mustang sites have info that will help.
http://www.428cobrajet.com/speedo-calc.html
http://www.boss302.com/speedo.htm
Tim
  #4 (permalink)
Old 03-16-2005, 02:43 PM
cool.
so, a 8.75x16.5 tire is 29.5" tall...
I used 245/70-16 tire size, which is a 29.5" tall tire for the calculator...
Tire circumference: 92.68927 inches
Optimal driven/drive ratio: 2.54973
Closest matching ratio (difference of 0.04973): 2.5
Driven gear: 20 teeth, C8SZ-17271-B (Orange)
Drive gear: 8 teeth, part of transmission output shaft
The 3.73's are noticable over the 3.54's... nothing silly, but, I like them.
__________________
Mike H.
1969 F250
1992 5.0 lx coupe.
  #5 (permalink)
Old 03-22-2005, 10:34 PM
well.
I picked up the 20 tooth plastic gear and crawled under to make the swap.
Much to my suprise, the gear in the tail housing is steel, and rather long, no c-clip, the square inner cable exttends directly into the steel gear casting.
What am I to do now?
Where would I find one of these steel units?
Mine had D21 stamed on it. guess I should have checked to see if that meant 21 teeth...
__________________
Mike H.
1969 F250
1992 5.0 lx coupe.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
