Trailer Wiring Plug
Trailer Wiring Plug
I need some help on this one! I am converting my 03 250 over to a 7 pin plastic plug on the back of my truck. It had a 6 pin metal round plug on it when I bought it, and someone cut into my harness. So who has the wiring diagram for the back of my truck? There is 8 wires back there, and I only need 7. Any help is apreciated!
Here are the colors and pins for a 7 pin connector. What the 8th wire does is unknown in this case. The wire colors should match but if not the 6 pin horse trailer wires are listed after the 7 pole. You should be able with this to figure out what function is what. You can get a 12v tester for about $2.00 if you do not have a meter to measure which one is on when you turn on the different functions. I would hope that the wires in the truck match the standard colors so it should be easy to change connectors.
7 pole RV plug/socket.
# Wire Color Function Location-Truck socket Location Trailer plug
1 White Ground 7:00 o'clock 5:00 o'clock
2 Blue Brakes 5:00 o'clock 7:00 o'clock
3 Green Running 10:00 o'clock 2:00 o'clock
4 Black Power 2:00 o'clock 10:00 o'clock
5 Red LT & Stop 9:00 o'clock 3:00 o'clock
6 Brown RT & Stop 3:00 o'clock 9:00 o'clock
7 Yellow Aux or BU Center Center
6 Pin Connector
Terminal Marking Wire Color Function
GD White Ground
TM Brown Running Lights
LT Yellow Left turn/brake light
RT Green Right turn/brake light
ST Blue Brake Control
Aux Black Power
6 Pin Connector
GD White Ground
Aux Black Power
I still can not figure it out. This is what my truck has:
Orange-?
2 blue- electric brakes?
Yellow- Left turn
Green- Right turn
Brown- Tail
Black-?
White- Ground?
My plug has this:
White-Ground
Yellow-Left Turn
Green-Right Turn
Brown-Tail
Purple-Reverse
Blue-Elec. Brakes
Black-Auxilliary Power
Now how do I hook this up?
Orange-?
Yellow- Left turn
Green- Right turn
Brown- Tail
Black-?
White- Ground?
My plug has this:
White-Ground
Yellow-Left Turn
Green-Right Turn
Brown-Tail
Purple-Reverse
Blue-Elec. Brakes
This site below has photos that Bruce1026 was talking about.
http://firefyter_emt.tripod.com/elec.htm
Originally Posted by 99f350sd
All the trailer circuts have there own fuse under the hood if I'm not mistaken.
ekeller, if you want that back to stock appearance you can trace the wire for your trailer harness back (i think almost to the left tail light) and you will find a connector there. You should be able buy the factory 7 pin with the flat 4 pin on the bracket from Ford. This is a better, sealed unit than the aftermarket 7 pin plugs. We need everything sealed up here in Michigan all that d**n salt they use is hard on trailer wiring.
Toyman
Toyman
1fixitman
01-11-2013 12:20 PM
rog22
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
04-22-2003 10:07 AM
