CornHusker T-5 Transmission Kit and a 226 Flat 6 - Ford Truck Enthusiasts Forums
Old 03-15-2005, 11:03 AM
Christopher2's Avatar
Christopher2 Christopher2 is offline
Christopher2 is starting off with a positive reputation.
Post CornHusker T-5 Transmission Kit and a 226 Flat 6
First I would like to keep this to the 226 Flat 6 motor. I do not want the, it should work or may work. I would like the it does work and I have done it information. I would also like references to any pages that did the conversion on the 6 cylinder motor. I sent Cornhusker an email and am waiting for a reply. I have read bits of information here and there on the internet about various kits. I have read the threads here also but I never seem to get any definitive information. I am seriously thinking about doing this before I get the driveshaft made. Has anyone used this kit? I see in the pictures the transmission has a hydraulic clutch. Anyone here have any pictures of a hydraulic clutch setup with the factory pedals? I assume I would need to sketch a rear transmission bracket and have it made and add that. I would still be using the factory bracket for the pedals so I would need to use it or build a new one out of pipe. Will the factory starter work or will I need to get one out of something else? Will I need the S-10 starter?
Old 03-15-2005, 03:57 PM
Gary Mussman at Corn Husker said it should fit and I should be able to use my stock linkage.
1978 Ford f250 cummins swap brake booster 1978f250cummins 1973 - 1979 F-100 & Larger F-Series Trucks 0 09-19-2016 08:21 AM
226 transmission stein11587 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 06-16-2016 02:23 PM
ZF5 clutch hydraulic issue Bubba Jones 1994.5 - 1997 7.3L Power Stroke Diesel 5 05-19-2016 10:08 AM
T5 Install (start to finish) sere0501 1948 - 1956 F1, F100 & Larger F-Series Trucks 63 05-06-2015 10:13 AM
1955 Ford F350 Truck Clutch, Brake, Hanging Pedal Assy Conversion Johnnynobody 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 01-24-2015 02:19 AM
Tags
226, carburetor, corn, cornhusker, cyl, cylinder, flat, ford, husker, huskers, kit, linkage, t5, trans, transmission, transmissions
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
