Tranny/driveshaft squeal when driving..... - Ford Truck Enthusiasts Forums
Old 06-04-2001, 12:02 PM
Trips7772 Trips7772 is offline
Trips7772 is starting off with a positive reputation.
Hey there guys, question for ya...I have got a 96' 2wd F150 with a 4.9L and the AOD Tranny. The Problem is that when I am driving there is a squeal that sounds like it is coming from where the Driveshaft is slipped into the tranny. I checked the Ujoints and they are ok, but in the owners manual it says they are supposed to have pinhole type grease points, but they don't . They are sealed. But in the driveshaft, at where it is slipped into the tail end of the tranny there is hole, that looks like it could be a greas point. Is this a grease point or is it some kind of seepage hole, or vent hole. Any body have any experience with this...Thank you much... Trips7772(No Email Addresses In Posts!)
Old 06-04-2001, 02:33 PM
larry derouin larry derouin is offline
larry derouin is starting off with a positive reputation.
The hole you see on the end of the yoke between the ears (where the U-joint attaches is a vent hole so the yoke can "slip" fore & aft on the Transmission tailshaft.
You can have a dry joint and it will feel ok. Worst thing the manufacturers did was install "sealed" U-JOINTS.....
Joints are relatively CHEAP compared to replacing a shaft with associated costs of balancing and installation.
Go ahead and replace them and make sure they have grease fittings (zerk fittings).
Larry
Old 06-06-2001, 02:00 PM
Hey larry, thanks for the info.... I called a bunch of places and went to quite a few also, and no one knows a thing. I appreciate the help... This weekend I will be doing U-joints...
Thanks, Jeremy
Old 06-06-2001, 07:33 PM
cgl cgl is offline
cgl is gaining momentum as a positive member of FTE.
Strange transmission issues Kdr358 1999 to 2016 Super Duty 2 03-29-2014 01:21 PM
Squealing 6.0 BCHauler 1999 to 2016 Super Duty 3 09-06-2012 01:30 PM
driveline squeal 3cv 1999 to 2016 Super Duty 18 03-28-2012 12:28 AM
Point of Concern re Greasing Slip Yoke Quikirk 1999 to 2016 Super Duty 1 05-10-2003 12:48 PM
Hot AOD TRANNY/and Inline magnetic Tranny filter Trips7772 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 06-09-2001 04:04 PM
Tags
1980, 1999, 2001, 2005, 2wd, coming, drive, driveline, driveshaft, driving, explorer, f100, f150, ford, shaft, squeak, squeal, squealing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
