engine immobilizer - Ford Truck Enthusiasts Forums
engine immobilizer
Old 03-13-2005, 10:35 PM
Snow-man Snow-man is offline
Snow-man is starting off with a positive reputation.
engine immobilizer
i am stuck with 3 way cut off system, all has to be connected for it to function but I have a problem, it is designed to cut of starter, coil and fuel pump but I don't have an electric fuel pump, is it possible to break one of the other cut offs twice or could i dummy it to something like the alternator...
Old 03-14-2005, 02:58 AM
midlf midlf is offline
midlf is starting off with a positive reputation.
Do you HAVE to use all three? Unless the system is looking for input from the interupted circuits it would seem unnecessary to hook it up.
Old 03-14-2005, 11:11 PM
cut off
yeah... it all has to be hooked up...
Old 03-15-2005, 01:44 AM
I'd call the mfr help line or website. This can't be the first time this problem has come up.
Fuel pump cut off switch tomasz646 1968-2013 Full Size Vans 4 09-24-2012 08:26 PM
2000 ford explorer MJGRAY66 Explorer, Sport Trac, Mountaineer & Aviator 4 06-15-2008 08:47 PM
fuel pump wire? Nyborg 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 05-24-2008 07:31 AM
no power to fuel pump suprdzlduty 1999 - 2003 7.3L Power Stroke Diesel 10 03-09-2008 01:20 PM
FUEL PRESSURE PROBLEM? jburke 1987 - 1996 F150 & Larger F-Series Trucks 3 10-14-2001 01:34 AM
Tags
engine, ford, immbolizer, immobilizer, system, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
