front gas tank overflows
as you will find in this forum, fuel problems with the duel tank setup are a common thing. ford has issued a recall because the front tank filling the back tank and visa versa is a common problem that they have corrected by installing in-line check valves at the tank sender. so you may be having the same problem and your front tank is already full from fuel from the rear tank. good luck
the filler neck could be kinked or blocked by somthing. slide up under there and take a look at the filler pipe. the big one that you can see isnt wat the gas travels through, theres a smaller pipe inside. make sure that it isnt bent real sharp and squeeze it up and down to make sure there isnt something blocking it. otherwise, i would check the vent coming out of the tank and see if its cloged because if it is then it wont vent and will pressurize and shoot back out. hope this helps.
motman
06-12-2013 09:48 AM
Dead Meat
10-06-2009 12:52 PM
Woodyp
04-14-2008 12:55 PM
