rear window air leak
Old 03-13-2005, 11:52 AM
guessrow's Avatar
guessrow
guessrow is offline
Hi everyone,
I have a 99 Ranger with a solid rear window. Lately, I've been noticing extra noise and vibration from the lower part of my rear window. I got to checking it out this morning, and found that the trim around the window is coming loose from the body of the truck. (The window is properly attached the window trim, but the trim seems to be coming loose from the truck) It appears to be loose all the way across the bottom. When I close the door on my truck, I can see the window bulging to let air out. (I'm assuming thats how this all came about in the first place. This is the factory window, never replaced.
The real question is what to do from here... could I apply sealant or adhesive to the loose area? Pop the whole window out and reseal it? Take it to a body shop and let them do it? Cost is in issue here but preventing the problem from returning is probably a bigger one.
Thanks for you replies, Jim
p.s. any idea what a body shop might charge for such a repair?
will my insurance glass goverage cover this?
Old 03-13-2005, 03:22 PM
Ken00's Avatar
Ken00
Ken00 is offline
My manual shows the window is bolted in, are they tight?
Old 03-13-2005, 06:52 PM
guessrow's Avatar
guessrow
guessrow is offline
you were right..
Ken, you were right. I pulled some of the interior trimwork back and I found three loose bolts. I just got my tires balanced(professionally) and now a quiet rear window! I have to go to the dentist tomorrow morning to get a lost filling replaced, but at least I'm psyched for the drive!!
Thanks a lot!
Jim
Old 03-14-2005, 07:13 PM
Ken00's Avatar
Ken00
Ken00 is offline
Glad you got it fix, have fun at the dentist, zsszszszsszszszssz.
bahamian ford
1997 - 2003 F150
10-25-2011 10:24 AM
93 mix 'n match
1997 - 2003 F150
04-23-2010 11:35 PM
zxsmyers
1997 - 2003 F150
07-15-2009 10:36 PM
Nightrain
Paint & Bodywork
08-29-2006 01:25 PM
CJK440
1997 - 2003 F150
02-01-2005 04:30 PM
Quick Reply: rear window air leak
