Dash Bezel around Gauges - Ford Truck Enthusiasts Forums
Old 03-13-2005, 12:39 PM
CantedValve CantedValve is offline
CantedValve is starting off with a positive reputation.
Hello! I have a 1994 F150. I have a problem with the black bezel that holds the AC vents and the 4x4 buttons. THe button cluster is held to the bezel with a pair of screws. The screw bosses have broken off. Same story for the fuel tank switch and the clips that hold the bezel to the dash (those broke while I was trying to get the bezel off to fix the preceeding problems). I have had no luck with glue.
Basically, I am looking at having to get a new one. Can replacements be found (be they NOS or aftermarket) for this piece? Anyone have one in good condition they would part with? I looked on ebay with no luck.
Old 03-13-2005, 01:51 PM
frederic's Avatar
frederic frederic is offline
frederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to all
they're on ebay every so often. I see them in junkyards once in a blue moon also.
If the breakage is on the back side, not the front, you can fill in the screw hole area with epoxy, then redrill the holes.
Old 03-13-2005, 05:02 PM
frdtruc1 frdtruc1 is offline
frdtruc1 is starting off with a positive reputation.
Check out LMC Truck catalog @ www.LMCtruck.com
You can order a catalog (free) specific to your year. They have 2 full pages on dashboard compontents in the winter issue that I have. It is an excellent reference to decide on getting new, aftermarket, or junkyard parts.
Old 03-13-2005, 06:09 PM
Thank you very much guys!
Old 03-13-2005, 08:15 PM
MemOrex MemOrex is offline
MemOrex is starting off with a positive reputation.
Back when my dad drove this truck, the Fuel switch screws broke. He used super glue and it looks bad. It kinda 'melted' the plastic. Don't use super glue.
Instrument Bezel Question. 2005REDFX4 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 10-21-2014 07:13 PM
Instrument Bezel Question. 2005REDFX4 1987 - 1996 F150 & Larger F-Series Trucks 4 09-27-2014 12:01 PM
binding cylinder inside ignition switch Becky_is_a_66 1961 - 1966 F-100 & Larger F-Series Trucks 19 07-11-2014 05:20 PM
1978 F250 with a/c & spotlight - no left vent? hhight 1973 - 1979 F-100 & Larger F-Series Trucks 6 07-10-2014 11:44 AM
Dash Bezel trade? 4x4slik 1973 - 1979 F-100 & Larger F-Series Trucks 8 05-16-2014 10:01 AM
Tags
1993, 1994, 1996, 2008, 78, bezel, broke, clips, dash, dashboard, f150, ford, gauge, guage, hole, screw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
