is there a tag on the rear?? you will probably have to post the numbers on it in here......i searched this forum and didnt come up with anything about different sizes..........
There should be a part number on seal after you get it out..Go to Ford dealer, should be around $4. Might as well replace both...Just make sure you put the right grease back in rear dif.
