86 ford truck xl no start no crank no power
Old 09-18-2014, 07:49 PM
Subaru Sti's Avatar
Subaru Sti
Subaru Sti is offline
Truck no start no crank no Power .. truck was runing stalled it on red light (manual transmisión ) Truck did not want to start I notice hot wire from starter selonoid to battery . replaced Starter selonoid in Truck . Truck started and ran fine turned Truck off and tríed Turning back on . Truck did not turned on . truck Wanted to start on its own after switch off set for 30minutes turn truck off. What its causing it to trip like that ? . Still don't run
I have check all connection they clean and tight just replaced starter alternator battery and starter selenoid on this truck but Can not find starter relay .... Help!! Note this 1986 ford xl f350 tow truck was diesel and has been converted to gas engine
-all wire harness is from Diesel engine help..
Old 09-19-2014, 10:41 AM
Rovernut's Avatar
Rovernut
Rovernut is offline
I'm having a really hard time figuring out what you're saying and asking.
I'm not even sure why you're replacing the solenoids.
Could you try editing your post and using better punctuation and complete sentences?
Old 09-19-2014, 11:03 AM
1986F150six's Avatar
1986F150six
1986F150six is offline
Subaru Sti,
Welcome to the forum. As Rovernut said, you will get more responses if you take the time to express your thoughts and questions clearly.
It will be difficult to help over the Internet due to the fact that your truck has been modified from the factory set-up [i.e. diesel to gas conversion utilizing diesel wiring harness].
When a starter solenoid fails, it is considered best by many forum members to replace with a Motorcraft unit. Some new solenoids of lesser quality are frequently "bad" out of the box or fail within a short time due to poor quality. Some members routinely get "old" Motorcraft solenoids while at a junk yard and keep as spares.
Good luck!
BuckYoung
12-21-2015 07:37 PM
Subaru Sti
09-20-2014 07:01 AM
dan_E350
17
07-05-2011 05:19 PM
dcwpainting
03-05-2009 01:13 PM
MikeSmithFL
Electrical Systems/Wiring
02-07-2002 03:10 AM
Quick Reply: 86 ford truck xl no start no crank no power
