86 BALLAST RESISTOR ?'S
Old 09-19-2014, 10:18 AM
86fn150's Avatar
86fn150
86fn150 is offline
converting my 86 351 4bbl to 95 351 efi using stang stuff.getting conflicting info.searched and can't find the any relevant info other than this
https://www.ford-trucks.com/forums/1...it-needed.html
.supposedly a 4ft red/green 16gauge wire ??is this correct. I don't see it in any diagrams .I'm assuming It's not needed with EFI.any info on where it starts/ends is greatly appreciated
thanks in advance,
andy
Old 09-19-2014, 02:41 PM
JimsRebel's Avatar
JimsRebel
JimsRebel is offline
Did your truck originally have a DS2 system?
The best answer is just to use a relay to power your new IGN system.
Jim
Old 09-19-2014, 02:53 PM
86fn150's Avatar
86fn150
86fn150 is offline
truck has DS2 factory.found this is this the correct one?does it go right to ign switch?
on post #15
https://www.ford-trucks.com/forums/1...-problems.html
can i just delete.tap in just before this pink(supposedly )resister .I just need a ignition wire with run /start power which the red/green seems to be(also the wiring color on my ford racing harness)
Old 09-19-2014, 03:16 PM
JimsRebel's Avatar
JimsRebel
You should be able to see a coil wire (pink) near the IGN switch which is the other end of the resistance wire.
You truck will just have 2 wires in and 1 wire out (post 15)... and yes this is the feed point you are looking for.
But still, l a relay is the easiest and best choice. The new IGN system will draw more amps and taxes the existing wiring.
JIm
Old 09-19-2014, 03:25 PM
86fn150's Avatar
86fn150
86fn150 is offline
JIm
a relay at the red/green wire and use it to trigger the wiring??the ford racing harness needs a start and a start/run wire .(which happens to be color coded the same as the 86 wiring.for the start I'm using the blue/red(?) wire that feeds to the starter solenoid on fender and looks like the red/green wire is start/run.the main power for the computer and harness etc is a 10 gauge wire direct to battery
Old 09-19-2014, 03:50 PM
JimsRebel's Avatar
JimsRebel
The start wire will be the single small wire on the fender mounted starter solenoid.
The run/start can be as easy as removing the wire on the coil positive and using it to power a relay. The relay when energized would provide power to your new IGN system.
Full Power to HEI
Jim
86fn150
16
10-15-2014 10:05 AM
Pkupman82
Electrical Systems/Wiring
01-13-2010 01:07 PM
mamafedmepaintchips
12-05-2003 01:58 AM
billemc
11-25-2003 10:46 AM
labrouse
04-14-2003 09:58 PM
Quick Reply: 86 BALLAST RESISTOR ?'S
