302 Ford Cylinder Numbering and Firing Order V8 - Page 2 - Ford Truck Enthusiasts Forums
Old 12-16-2012, 04:32 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Don't kid yourself. Do you think if Ford could have designed the system with a wider plug gap, and gotten 2 or 3 more mpg they wouldn't have just done it? They were strapped by emissions rules, but that's about it. There was no conspiracy to make all their trucks use more fuel.
Old 12-16-2012, 04:46 PM
1983F1503004x4 1983F1503004x4 is offline
1983F1503004x4 has a very good reputation on FTE.1983F1503004x4 has a very good reputation on FTE.1983F1503004x4 has a very good reputation on FTE.
Quote:
Originally Posted by Old81F100Brown View Post
So far I haven't seen an answer that I can work with. I need more than guesses. I will keep searching for a better answer. Like I found cowl Induction hoods might give me 7 more MPG. There has to be an answer. Or a combination of answers. Money is a problem. Some of the answers are too expensive. But I am learning more and more. I have found that the more I search the more I get closer to an answer. I just have to keep on trucking tell I find what I can work with. Thanks for your help.
A cowl induction hood is not a magical device for more gas mileage, despite what whoever it is might be claiming. These trucks are bricks, and the best MPG you'll get out of your 302 will be around 18 mpg in peak condition and tune with the proper components.
You'll have to provide us with better information in order for us to help you. If not, we can't do anything.
What kind of transmission do you have?
Is it 4 wheel drive? Are your hubs locked and the transfer case engaged?
What gearing does your truck have?
How fast do you drive?
Has the carburetor been rebuilt?
Have you tuned the carburetor's mixture with a vacuum gauge?
Check for vacuum leaks?
These are just the basic things, and in order to help more, we'll need information.
Old 12-16-2012, 05:37 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
Spark plug gap of .041?
Follow the gap recomendation on the emissions decal. Usually between .042-.046 with an average of .044 .
Old 12-16-2012, 11:06 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Old 12-17-2012, 12:34 AM
Anafiel's Avatar
Anafiel Anafiel is offline
Anafiel has a very good reputation on FTE.Anafiel has a very good reputation on FTE.Anafiel has a very good reputation on FTE.Anafiel has a very good reputation on FTE.
I find that If I keep looking something will show up.
Yup, I'm absolutely convinced that if you look long and hard enough, you'll certainly find someone to provide you with an answer that fits your preconceived notion of what that answer needs to be to satisfy you.
Now, whether that answer lives in reality is indeed another story.
just sayin...
Old 12-17-2012, 12:10 PM
Old81F100Brown Old81F100Brown is offline
Old81F100Brown is starting off with a positive reputation.
Other peoples or "professional" tune ups
I have actually stood and watched professionals do nothing but change the oil (Midus Muffler) bet they would not let me into the shop area. It took me almost 6 months of checking vacuum hoses and tracing to find what had happened. It started to run ok again but at the price of horrible gas mileage, no HP and all my time pulling my hear out. This is a 1981 5L engine with a 4 on the floor (3+Overdrive) and let me tell you, NO ONE knows what they are doing on your truck. Don't loan it out (it isn't appreciated) and document what you do to fix things. I loaned mine out and the guy said "I guess I didn't get the back latch done right and the tailgate fell off at an intersection". I bought this truck almost new and had the engine rebuilt by journeymen mechanics. It's as if they develop a personality and will not work for anyone but you. If you want it done wrong, pay $125 an hour to a professional shop. Or just start drawing diagrams, taking notes, read your manual, AND NEVER LOAN IT OUT!!
Quote:
Originally Posted by RyanLeeSparks View Post
I just wanted to say thanks for posting on the firing order of a 302 ci. I lent my truck to some family so they had a four wheel drive for the winter and for hauling wood, when I returned it ran like garbage. They told me they had done a "tune up" on it and it still ran horrible. I have spent the last few days trying to figure out what was wrong and even did another "tune up" of my own i.e, Cap, rotor, plugs, wires, air filter, Oil, Oil Filter. Still to my dismay it ran horrible. Apparently 16 year olds should not replace a cap and rotor without a guide because the young man had the firing oreder all messed up and when I replaced the cap and rotor myself I "assumed" (dumb of me) that it was correct. After reviewing your post and checking it was completely wrong I'm not sure how it even started or ran but it did...now IT IS AWESOME!!!! THANK YOU!
Old 12-17-2012, 12:25 PM
A proper "tune up" for your motor would be to first get the regular maintenance items out of the way, then check technical stuff.
Drain and flush coolant, new 50/50 antifreeze.
Run the motor up to operating temperature (take it for a drive and come back, this way you know the oil is hot), shut it off, then drain the oil. Replace with factory viscosity or slightly higher and a Motorcraft oil filter (avoid the orange can of death).
New spark plugs, spark plug wires, cap, and rotor button.
Rebuild the carburetor (probably needed after 31 years), new jets, floats, accelerator pump diaphragm, etc.
Tune the fuel mixture with a vacuum gauge, check for any vacuum leaks, and make sure everything is tight.
Re-check the timing on your motor and set it to either factory specs or slightly advance by about 2*.
That should have your motor running beautifully. If not, then there's problems elsewhere or you missed something.
Old 12-20-2012, 12:37 AM
just sayin...
Heavy Man...Far Out....
Old 03-30-2013, 12:01 AM
Kyle Charters Kyle Charters is offline
Kyle Charters is starting off with a positive reputation.
Sounds like you, OldF100Brown are not really looking for an answer. Not one perosn can tell you what is wrong with your truck without you giving them all the info and specs regarding your truck. They can help by answering any questions or giving advice but you have to be willing to help them out to help you out. Ask informative questions dont just assume every body knows everything before you tell them anything because they wont know what you have or what you've done or havent done. so give them more info and you may just be able to finally get your answer
Old 01-05-2014, 05:04 PM
CarolinaCanes's Avatar
CarolinaCanes CarolinaCanes is offline
CarolinaCanes is gaining momentum as a positive member of FTE.
this site rocks. thats all i got
Old 01-06-2014, 09:35 PM
Quote:
I have read my post over and over, and I don't get that I am asking a question. I am just stating don't loan your truck out to people and posting what has happened when I did. I don't have a problem that I need help with....what did I say that made you think I was asking for help on a question?
Old 01-06-2014, 09:39 PM
Oh I see, going back to the original post. Pardon me, but I was and still am and will always be, looking for a way to make my rig more fuel efficient. I have found a couple of things that may work. But I will not post them until I have made sure that they do work or don't work, and then I can post more responsibly.
  #28
Old 01-07-2014, 07:24 AM
Didn't mean to dig up old bones. I realized how old the thread was after I posted.
I was in a hurry and needed this exact info the op posted. Amazes me how fast things can be found.
  #29
Old 01-08-2014, 07:55 AM
reamer's Avatar
reamer reamer is offline
reamer has a very good reputation on FTE.reamer has a very good reputation on FTE.reamer has a very good reputation on FTE.reamer has a very good reputation on FTE.
Ya might have to give the husband of the original post (firing order wrong) a break! The truck I just picked up was not running and needed and exhaust manifold, (thanks for the help here on that one) well put new manifold on and have to put wires back on. looked at the ORIGINAL emissions sticker on core support, (engine and core support are original)
The emissions sticker claims it's a 351!
Its a 302 (heads are close to the block) Ignoring the sticker and did the 302 wiring, fired right up!
  #30
Old 01-08-2014, 09:07 AM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is offline
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
Quote:
As I think about it, all the engines I've worked on have had the heads close to the block. Actually, .049" away from the block in many cases. Wow! A 302 with W-shaped valve covers? And a 302 with the valve cover held on by stove bolts? And a V6 as well as a 4 cylinder 302? And even an air-cooled 302!
1988 F259 w/ New 7.5 efi installed, will not start. EDsurvivor 1987 - 1996 F150 & Larger F-Series Trucks 16 09-08-2016 02:30 PM
Bronco xlt 87 Crank no start error code 23 23 Throttle Position Higher Or Lower Than Expected Thorvar 1978 - 1996 Big Bronco 3 06-06-2016 05:44 AM
352 firing order is correct but on different distributor locations asmith6 1961 - 1966 F-100 & Larger F-Series Trucks 6 03-06-2016 01:36 PM
What I have done to my 1985 F250 5.0L Hopsing69 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 01-04-2016 01:37 PM
how come it ran jimmy dale 1987 - 1996 F150 & Larger F-Series Trucks 5 06-24-2014 06:56 AM
Tags
1997, 302, 50, 50l, 58, cylinder, f150, firing, ford, location, numbering, order, truck, umbering, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
