Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
  #1 (permalink)
Old 03-12-2005, 04:23 PM
Muffinman Muffinman is offline
Garage is empty, add now
Muffinman is starting off with a positive reputation.
95 dash bulbs,
I have a 95 and need to replace all the bulbs with my 8 watt ones. What is the best way to get at them. It not s Digital if that makes any differance.
  #2 (permalink)
Old 03-12-2005, 05:28 PM
copper_90680's Avatar
copper_90680 copper_90680 is offline
copper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant future
Sorry Muffinman:
The only way I know how to change the bulbs in the dash is to remove the dash itself. Not really tough, but not fun either. The last time one of the bulbs burned, I replaced all of them just to be sure I don't have to deal with it too soon thereafter.
  #3 (permalink)
Old 03-12-2005, 07:15 PM
RC135U RC135U is offline
RC135U is starting off with a positive reputation.
A handy tool to use for removing the dash is made by Snap On - it looks like
a blunter version of the tool gardeners use to dig out dandelions, bent and
with the "V" at the tip. Watched my mechanic use it when he replaced the
headlight switch. Come to think of it, that switch is somewhat notorious so
maybe you'd want to check it's condition while you have the dash off anyhow.
  #4 (permalink)
Old 03-12-2005, 08:21 PM
I am a well stocked Snap-On tool man, I thought I was going to have to remove that curved dash to get at all of them. One reason i do them all too.
Thought mayb someone had a trick to get around it.
  #5 (permalink)
Old 03-12-2005, 10:10 PM
93nighthawk's Avatar
93nighthawk 93nighthawk is offline
93nighthawk is starting off with a positive reputation.
Quote:
If you have thin wirery arms/hands (or have a willing wife/kid) you can reach underneath the dash and replace them. But it would probably be easier to just pull the instrument cluster.
__________________
'97 Ford Aerostar AWD 4.0L v6 AT 96k mi
'07 Ford Taurus SE 3.0 Vulcan ATX 52k mi,
My Car Domain --- The Possum Aero-Van!
ASE
Certified Parts Person
Ford Certified Master Parts Person
  #6 (permalink)
Old 03-13-2005, 01:57 PM
Man I had to take the whole front dash a part and the lower cover. I replaced ever bulb I found too.
I cleaned the inside as well while it was apart. I cleaned the AC duct, took the clear cover off the instrument cluster and cleaned it, Washed all the parts and used blue lock tight on the screws.
For those that need to know, Two sizes of Torks 10-15, A pick to remove headlight **** "Find the little notch and push the pick back towards the **** while pulling"
  #7 (permalink)
Old 05-06-2012, 06:42 PM
yitzy yitzy is offline
1997 Ford Aerostar
yitzy is starting off with a positive reputation.
So that's how to remove the headlight ****!! Thanks!
  #8 (permalink)
Old 05-07-2012, 12:59 PM
asavage asavage is offline
asavage is starting off with a positive reputation.
It's not so much the headlight switch that goes bad, as the connector at the headlight switch that overheats, melts, and takes out the switch.
IOW, if you have a failed HL switch, the connector usually needs to be replaced as well.
Hmmm. I see that I wrote a post last August on replacing this on my '93, just before I sold it to a friend, but that I didn't actually post it here, only on my own website. I'll go fix that . . . OK, posted here.
__________________
Regards,
Al S.
1997 XLT, extended, 4.0l AWD, 148k miles (Feb13)
1993 XL, extended, 3.0l, 204k (sold to a friend)
1989 XLT shorty, 3.0l, 232k miles (sold)
Tags
1995, 93, bulbs, cluster, dash, f150, instrument, panel, replace
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
