Need help on a Holley 4160 rebuild. - Ford Truck Enthusiasts Forums
Old 03-12-2005, 11:24 AM
HawgDawg's Avatar
HawgDawg HawgDawg is offline
HawgDawg is starting off with a positive reputation.
This is my first time on a Holley rebuild and I have a couple of questions. Would appreciate any help. Carb is a Holley 4160. List #6919.
1. Replacing the accelorator pump - The diagram shows a check ball above the acc. pump but there wasn't one when I took the old one apart. Is this something that should be there?
2. Concerning the pump discharge nozzle - Diagram shows a "pump check ball weight" and a "Pump Discharge Nozzle Check Ball" below the pump discharge needle valve, neither of which I remember coming out. Are these absent on some models? or did I misplace them.
Thanks in advance.
HD
Old 03-12-2005, 03:54 PM
HawgDawg's Avatar
Never mind. I got it!!!!!!
Thanks anyway
HD
Old 03-13-2005, 11:41 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Did ya find them? The acc pump check ball is usually held in by a small strap.
Old 03-13-2005, 12:56 PM
HawgDawg's Avatar
Yeah, I found em. The strap that holds the acc pump ball in had fallen out before I took the carb apart and was stuck between the metal and the diaphram in the acc pump. After spending hours searching the work bench and floor around it I decided to take a chance and dug the old acc pump out of the trash. There it was. Never found the ball but there was a replacement in the kit.
got the carb together and it runs fine.
Thanks
HD
Old 03-14-2005, 12:51 AM
LxMan1's Avatar
Good deal, glad you got it going
Should a dealer get away with this? CMill250 6.7L Power Stroke Diesel 27 09-22-2015 01:59 PM
351 Windsor Build Micbruff 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 23 11-05-2014 09:17 PM
IMPORTANT - Diesel Fuel Quailty & Warranty pbruckne 6.7L Power Stroke Diesel 71 12-18-2013 04:47 PM
Mods, Maintenance, and Life(long and kind of pic heavy) redman84 1994.5 - 1997 7.3L Power Stroke Diesel 17 05-29-2013 01:38 PM
Holley carb help needed 77-250 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-26-2010 07:56 PM
Tags
4160, ball, check, diagram, discharge, holley, kit, location, need, nozzle, nozzles, pump, rebuild, rebuilding, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
