'05 F150 Vehicle Speed Sensor
Old 03-11-2005, 09:08 AM
curranporto's Avatar
curranporto
curranporto is offline
Hey folks: I'm losing my mind trying to find the VSS lead for my GPS (so my wife won't make me stop and ask for directions - you know what I mean). It's too new for the wiring specs to be out. Anybody found it? Thank you.
Old 03-11-2005, 03:05 PM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
Older trucks have the VSS on top of the rear diff. I'm sure things haven't changed too much.
Old 03-11-2005, 08:36 PM
curranporto
Thanks, but no go. I believe the wiring harness is on the fire wall passenger side, but I cannot identify the correct wire.
Old 03-11-2005, 08:59 PM
DonsFx4's Avatar
DonsFx4
DonsFx4 is offline
Looking at the 2004 F150 WDM
The rear axle speed sensor goes straight in to the ABS control module (located in eng comp, left side fender below air snorkle), via a twisted pair wire. One is Light Green w/ Black stripe and the other is Light Green w/ Red stripe. They hook into terminals 22 and 23 of ABS plug C135. From there it goes to the PCM and, via splices, to the insturment cluster. The output from the ABS module is another twisted pair; one wire is White w/ Light Green stripe (CAN Bus +) and the other is Pink w/ Light Green stripe(CAN Bus -).
The PCM is located on the r/h upper firewall. The wires (W/LG and P/LG) are on terminals 2 and 3 of PCM connector C175b.
Hope this helps!!
Old 03-12-2005, 06:24 AM
Lashlaroo's Avatar
Lashlaroo
Lashlaroo is offline
I have to ask. Why does your GPS need speed info from your truck??????
Old 03-12-2005, 11:00 AM
JohnnyBoy's Avatar
JohnnyBoy
JohnnyBoy is offline
I fit is a mounted GPS(AKA Navigation) my guess would be to plot the landspeed of the truck in relation to the sattelites. I really dont know much about GPS, guess thats why I keep getting lost, huh?
Old 03-13-2005, 08:11 AM
curranporto
Donsfx4: Thank you. That was a very complete answer, and think it is exactly what I need. I'll take a look and drop you a note. more
Lashlaroo and Johnnyboy:
I can not figure out why it needs a speed sensor. I thought the position of the sats relative to the movement was enough to calculate the speed. You know, it's a math thing! Now, there is a plausable reason for not knowing what the heck is going on.
Actually, I believe that the monitor uses the sensor to reset its calculation automatically and more accurately read out the speed and estimate distances. Not sure though, but I think that is what Johnnyboy was stating.
Thank you folks.
Curran
MARTYSTOWRIG
1999 to 2016 Super Duty
215
07-14-2008 10:13 PM
51dueller
16
09-07-2007 07:02 PM
Quick Reply: '05 F150 Vehicle Speed Sensor
