Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 03-11-2005, 01:26 AM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold
How to replace your Super Duty Ball Joints
I figured that with all the discussion on replacing these ball joints that the next time I did a set I would take pictures and do a write-up on it.
Some of the things can be done in a bit different order. This is just the way I do it.
These instructions can also be used for replacing the axle U-joints and the wheel bearing/hub assembly.
The ball joints wear out which makes them loose but sometimes they are too tight which makes the steering not return very well so it wanders.
Before you start make sure you have new outer hub O-rings, wheel bearing/hub assembly O-rings, knuckle seals, axle dust seals and cotter pins as well as the ball joints or U-joints or wheel bearing/hub assemblies or whatever you are replacing. If you are replacing the wheel bearing/hub assemblies you might want to have new studs and nuts for them on hand too.
Click on the colored words to link to pictures of the procedures.
This didn't all fit on one page. Maybe that can be fixed later
__________________
Dave - FTE moderator
Forum Guidelines
this space for rent
  #2 (permalink)
Old 03-11-2005, 01:27 AM
Racerguy's Avatar
1) Raise the front of the truck off the ground and support it safely either on a hoist or with a floor jack and proper jack stands. Don't use concrete blocks, pieces of old wood etc. Having the truck fall on you will ruin your day
2) Remove the front wheels.
3) Unplug the connector for the ABS sensor from behind the inner fender liner. Unclip it from the frame and from the brake hose.
4) Pry the caliper away from the caliper mount to compress the pistons in the caliper. Remove the bolts that hold the caliper mount to the steering knuckle and set the caliper and mount on top of the spring . Don't let the caliper hang by the hose. Also remove the vacuum hose that goes to the fitting on the knuckle if you have ESOF.
5) Remove the brake rotor . It may take some persuasion.
6) Remove the cotter pin and nut that attach the tie rod end to the knuckle.
Hit the side of the knuckle where the end goes through to pop the end out. If you use a pickle fork (tie rod separator) on this you may destroy the boot on the tie rod end.
7) Remove the outer hub by squeezing the retaining ring and then pulling the hub out. Sometimes it will take a bit of persuasion with a soft faced hammer to remove it.
8) Remove the snap ring and thrust washers from the axle.
9) Remove the bolt that holds the ABS sensor wiring to the knuckle.
10) Remove the 4 nuts that attach the wheel bearing/hub assembly to the knuckle and remove it. There are a few ways to remove the wheel bearing/hub assembly. You might try using a long punch and hitting the studs from behind (make sure you have new studs first), you might be able to pound a thin chisel in between the assembly and the knuckle to break it free, you might be able to use a 3 jaw puller pushing against the axle or you can reinstall the wheel and hit the back of the tire with a sledge hammer. It can be pretty hard to remove but it will come off.
11) Now that you've got the wheel bearing/hub assembly off you'll see the axle needle bearing or spindle bearing as it's sometimes called. If it is dry you will have to replace it and maybe the axle too if there is damage on it. If there is still grease in it you'll want to clean it out and regrease it.
12) Remove the thrust washer from the axle and note which direction it came off. The 4 grooves go to the back.
13) Remove the axle. I usually just pry it out with a pry bar on each side behind the housing dust seal. You can also tap it out from behind.
14) I find it easier to remove the knuckle seal with the axle still hanging in the knuckle. It comes off with a hammer and chisel or punch.
15) Now you can clean up the axle and closely check the U-joint to make sure it moves freely and doesn't bind or feel loose. Also examine the axle for any unusual wear etc.
16) While the knuckle is still attached I like to clean out the inside of it. If it's rust and dirty the new seals won't seal properly which can lead to bearing problems and also cause the ESOF to not work right. I use a ball hone on a drill to clean it out. You can use fine sandpaper if you don't have a hone. The main thing is to make sure the inside of the knuckle is clean and smooth.
17) Remove the lower and upper ball joint nuts. Some new ball joints come with nuts, some don't.
18) Using a pickle fork, knock the upper and lower ball joints out of the housing. Keeping one of the ball joint nuts on a few threads will keep the knuckle from falling off and landing on your toes
Now remove the knuckle.
19) Clean the end of the housing and inside the tube.
20) Now you're ready to remove the ball joints.
Start by removing the snap ring from the lower ball joint.
Remove the old ball joints either with a ball joint press or by pounding them out. First the lower and then the upper.
Clean the rust and junk from where the ball joints go into the knuckle. I steam clean the knuckle but it's not usually really necessary.
In our shop we have drivers to install the new ball joints but most people use a ball joint press so I won't show you that part. You should be able to get a ball joint press from a parts store or rental place. It should have instructions with it. Basically it is like a big C clamp with cups and spacers etc that will press the ball joints into the knuckle.
21) Install the knuckle onto the housing again and loosely install the nuts on the ball joints. Tighten the lower ball joint nut to 150 ft.lb. Tighten the upper ball joint nut to 70 lb.ft. and install a new cotter pin.
22) Next, install the new knuckle seal onto the axle. You'll need the special driver made for doing that or some people have made drivers out of PVC pipe. The seal has to bottom out on the axle.
23) Install a new dust seal on the axle. It usually just pushes on by hand but you may have to tap on it a bit.
24) Lube the outer sealing surface of the knuckle seal with good quailty wheel bearing grease or silicone dielectric grease and install the axle. The same tool that was used for installing the seal onto the axle gets used to install the axle into the steering knuckle. The axle can't go in too far so don't worry about the seal pushing out the back or anything. The driver pushes the axle in to the correct depth. Lightly grease the thrust washer and install in onto the axle with the 4 grooves to the back.
25) Clean and lube the needle bearing with good quality wheel bearing grease. The bearing needs to be packed with the grease. Force the grease in with your fingers until no more will go in. Replace the yellow O-ring on the wheel bearing/hub assembly. Make sure the 4 studs are in good shape and clean.
Install the wheel bearing/hub assembly into the knuckle and tighten the 4 nuts to 135 ft.lb.
26) Lightly grease the outer thrust washers and install in the order shown and then the snap ring to hold it all together. You may have to pry the axle out a bit to install the snap ring.
27) Replace the O-ring on the outer hub and install the hub.
28) Install the brake rotor. I use 1 nut to hold the rotor on and tight while I install the caliper.
29) Install the caliper and mount.
30) Hook up the ABS sensor connector, vacuum hose etc.
31) Reattach the tie rod end. Tighten the nut to 50 ft.lb. and install a new cotter pin.
__________________
Forum Guidelines
this space for rent
  #3 (permalink)
Racerguy's Avatar
32) Grease the ball joints if they are greaseable and install the wheels.
The wheel nuts get torqued to 140-150 ft.lb.
Double check for any loose bolts, missing cotter pins etc.
Check the oil level in the front axle in case any ran out of the tubes while it was apart.
Lower the truck down to the ground again.
Pump up the brakes a few times before you take off.
Drive slowly to make sure that everything feels ok. Check to make sure the 4x4 works too. After a short test drive recheck for anything loose and check the wheel nuts again.
__________________
Forum Guidelines
this space for rent
  #4 (permalink)
Old 03-11-2005, 01:47 AM
Munkey's Avatar
Munkey Munkey is offline
Munkey is gaining momentum as a positive member of FTE.
Excellent write-up Racerguy! Good job!
I think this should be included in the FAQ or made into a 'sticky' thread.
__________________
Current: 1998 Toyota 4Runner SR5 4x4 V6 5spd.
Sold: 02 F-250 SC S/B, 4x4 4R100 4.30LS V-10 (I miss you, but you provided the down payment on our house!)
One day, I will drive a FORD again...
  #5 (permalink)
Old 03-11-2005, 03:29 AM
Chip57 Chip57 is offline
Chip57 is starting off with a positive reputation.
Thanks
This is what I was wanting!!
  #6 (permalink)
Old 03-11-2005, 08:33 AM
VIKING24 VIKING24 is offline
VIKING24 is starting off with a positive reputation.
Does anyone sell the driver for the knuckle seal or are they all home made?
__________________
2000 F250 SD SB V10 4x4 Lariat
  #7 (permalink)
Old 03-11-2005, 11:05 AM
LOOnatic LOOnatic is offline
LOOnatic is starting off with a positive reputation.
Good write up Racer.
Will use this when i do mine soon.
Thanks
__________________
04 F-250 6.0
List Mod's In Gallery
FTE
  #8 (permalink)
Old 03-21-2005, 11:40 AM
tazer tazer is offline
tazer is starting off with a positive reputation.
A person on this site sent me pictures of the seal driver-a person will probably want to make this. Also if you think the wheel bearing assembly is bad spend the $15.00 and get the new(from Ford) hub studs and nuts-both of these are from experience.
  #9 (permalink)
Old 03-21-2005, 01:02 PM
Racerguy's Avatar
Was it a home made seal driver? Do you still have the pictures?
__________________
Forum Guidelines
this space for rent
  #10 (permalink)
Old 03-22-2005, 03:56 PM
Yes it was a home made seal driver I got the pictures from a person on this sight. I purchased a commercial seal driver with different heads to accomodate a variety of seals that I was assured would work, but it was useless on the big front axle seals on Ford 99-02-I do not know if 03 and newer are the same.
  #11 (permalink)
Old 03-22-2005, 04:10 PM
It was either Brad99SD or 99f350SD, both of these people were very helpful when I did my ball joints and hubs and fixed my vacum leaks and it was one of them that had made a seal driver. When I first observed their picture I did not think it would work, but as soon as I took out the front axle I fabricated a seal driver very similiar. One of them can send you a picture and dimensions-I"m a dinosaur as I do not have digital cameras only film.
  #12 (permalink)
Old 03-22-2005, 07:57 PM
Racerguy's Avatar
Thanks
Hopefully one of them will read this and can post a picture.
Or if anyone else has made their own driver, we'd like to see.
__________________
Forum Guidelines
this space for rent
  #13 (permalink)
Old 03-22-2005, 08:46 PM
02superstroker's Avatar
02superstroker 02superstroker is offline
02superstroker is starting off with a positive reputation.
I think these are the pictures yall are talking about. They were in a previous thread, and yeah the pictures are from 99f350sd.
__________________
2002 Ford F-350 PSD SC LB
  #14 (permalink)
Old 03-29-2005, 10:30 PM
dagwood41's Avatar
dagwood41 dagwood41 is offline
dagwood41 is starting off with a positive reputation.
Your instructions are great!!!!
Thanks Racerguy,
I am a fairly decent mechanic but your instructions were right on and made the job a lot smoother. Took me about 3 hours to strip it all down and clean up everything. Both bottom ball joints were shot. The only difference are my axle seals they are a different type. Going down to the local parts store in the morning and see what I can get before hitting the local Ford dealer.
Thanks again
Rick
__________________
Rick
2008 F250 CC/SB 4X4 6.4 PSD auto
1996 Allegro Bay MH 460 Ford
84 Mustang GT 605 BBF / Glide
http://i237.photobucket.com/albums/f...tes050-1-2.jpg
  #15 (permalink)
Old 03-29-2005, 10:45 PM
Racerguy's Avatar
You're welcome
Let us know how it all turns out.
What kind of seal driver are you going to use?
__________________
Forum Guidelines
this space for rent
Tags
ball , change , f250 , f350 , ford , home , joint , joints , lube , made , press , removal , replacement , superduty , tight , torqued , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
