Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #121 (permalink)
Old 09-21-2007, 03:23 PM
jkpenny376 jkpenny376 is offline
jkpenny376 is starting off with a positive reputation.
is there anywhere to get a diagram of any of this?
  #122 (permalink)
Old 09-22-2007, 08:09 AM
ImBroke ImBroke is offline
ImBroke is starting off with a positive reputation.
Racerguy, thanks from me also for the excellent write up. I finished up with relatively no problems. I did break a vac nipple for the ESOF off on the drivers side. That knuckle was on there unbelievably tight. Took a sledgehammer to knock the knuckle loose, the ball joints did not want to let go. Trying to beat it off took a brass hammer, bigger brass hammer, mini sledge, and finally a full size sledge hammer. Passenger side came off easily. I copied your write up to a word document, and am putting socket sizes and other tools required, to make it quicker next time. Who would have thought of a 28mm socket?
  #123 (permalink)
Old 09-22-2007, 09:45 AM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold
You're welcome ImBroke
Good to hear another success story.
__________________
Dave - FTE moderator
Forum Guidelines
this space for rent
  #124 (permalink)
Old 09-22-2007, 11:19 AM
Hey ImBroke I would be interested to know all the tools needed when u get it done. And again is there a diagram or book of anykind that shows all this?
  #125 (permalink)
Old 09-22-2007, 12:32 PM
Racerguy's Avatar
jkpenny go back to the first page in this thread and click on the blue words in the write-up I did. Those will show you pictures of the procedure.
__________________
Forum Guidelines
this space for rent
  #126 (permalink)
Old 09-22-2007, 02:38 PM
Thanks racerguy for some reason I just looked over that part.....duh. What year model SD were u working on?
  #127 (permalink)
Old 09-22-2007, 02:47 PM
Racerguy's Avatar
I work on lots of them so I don't remember what year it was. Until 2005 they are all pretty much the same though.
__________________
Forum Guidelines
this space for rent
  #128 (permalink)
Old 09-22-2007, 03:04 PM
Ok that is good to know, mine is a 2004. Im not sure if I am going to have to rebuild the front end but if shocks dont fix my problem then the front end is next. Are parts from NAPA good or do u recommend anther place.
  #129 (permalink)
Old 09-25-2007, 03:35 PM
palindromelol palindromelol is offline
palindromelol is starting off with a positive reputation.
Excellant directions Thanks
I followed the directions and pictures and replaced my first set of Ball Joints. The guidelines here were perfect.
I'd like to add that separating the hub from the knuckle took me 1-1/2 days, 2 cans of penetrating oil and I needed a 5 foot pipe and a sledge hammer. It was on there hard! A truly difficult task.
The guidelines were great. Thanks.
  #130 (permalink)
Old 09-25-2007, 08:23 PM
Racerguy's Avatar
Good to hear you got it done
__________________
Forum Guidelines
this space for rent
  #131 (permalink)
Old 10-07-2007, 05:54 PM
twags6's Avatar
twags6 twags6 is offline
PAA Member #7 and FTE
twags6 has a good reputation on FTE. twags6 has a good reputation on FTE.
Hey guys. I seem to be going the same route as him. Any suggestions on how to make it easier to remove? I really hope this doesnt turn into days.
__________________
Trevor
01 F-350 CC 8ft bed SRW 7.3L a/t. 149k
PAA Member #7
  #132 (permalink)
Old 10-08-2007, 07:14 AM
Gnikhog Gnikhog is offline
Gnikhog is starting off with a positive reputation.
I found that using a punch mounted in my air chisel to drive the 4 hub to knuckle studs from the back made quick work of separating the two. I also found that after doing so, I needed to replace the studs - well worth the $15 expense in time saved. In fact, the stud kit comes with 4 studs, I only needed to replace 2 on each side (the ones I used the punch on).
  #133 (permalink)
Old 10-09-2007, 12:08 AM
twags6's Avatar
Quote:
How did you put the new studs in? It took a breaker bar and a stud removal tool to get mine out (kinda expected after hammering on them for 4 or so hours). The new ones start, but are hard to turn.
Thanks
__________________
Trevor
PAA Member #7
  #134 (permalink)
Old 10-09-2007, 11:43 PM
Quote:
Thanks
I removed the old studs with a pipe wrench. It didn't matter if I chewed them up because they were getting tossed anyway.
I installed the new studs by threading 2 nuts on one end of the stud and then tightened them against one another (but not bottomed out on the stud). Then I started the other end of the stud into the hub. Because the 2 nuts were 'locked' together I was able to put a socket on the top nut and thread the stud down into the hub without running the nuts to the bottom of the threaded portion of the stud. Once the stud was fully threaded into the hub, I loosened the 2 nuts from one another and backed them off the stud.
As I recall, I ran these new studs in most of the way with a rachet but they did require some effort. This may have been due to how they cut the threads in the hub or perhaps the original assembly used some threadlocking material.
Hopefully my explanation is clear.....
  #135 (permalink)
Old 10-20-2007, 06:42 PM
gitane59 gitane59 is offline
gitane59 is starting off with a positive reputation.
Thanks for the guidance and encouragement to takle this job on my own. My only problme was finding enough leverage and purchase to press out the ball joints. Once I got the joints out every went fine. I just wish i had bought tie-rod end as well as they are on their last legs. Thanks again Get Job
__________________
2001 F350 Lariat CC 2WD SRW SB V10 Two-Tone Green & Gold
2001 Newmar 34BLDS Kountry Star
Tags
ball , change , f250 , f350 , ford , home , joint , joints , lube , made , press , removal , replacement , superduty , tight , torqued , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
