Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #106 (permalink)
Old 05-20-2007, 08:07 PM
uponyou21 uponyou21 is offline
uponyou21 is starting off with a positive reputation.
great write up Racerguy did mine this weekend end only problem i had was the stud that holds the hub assembly in place was seized that took some time to do other then that not bad decided since i had the truck apart went and bought new rotors and pads
__________________
2003 F-350 XLT Sport 6.0L C/C, 8 inch lift 37"tires edge chip 4inch exhaust
List Mod's In Your Gallery
FTE
  #107 (permalink)
Old 05-21-2007, 12:02 AM
FYREDAWG FYREDAWG is offline
FYREDAWG is starting off with a positive reputation.
Everything was going fine with the ball-joint replacement until I replaced the outer thrust washers and attempted to put the snap ring back on. I could not get the snap ring back into the groove. I tried everything I could think of to pry the axle out to get the snap ring into the groove but no luck. I thought maybe the nuckle seal was not pressed all the way on but I checked and it seemed to be pressed all the way on.
Ideas???
Any help would be appreciated.
Thanks,
Ralph
99 F250 PS 4x4.
  #108 (permalink)
Old 05-21-2007, 05:03 PM
get a bigger pry bar to get the axle out more!!
__________________
FTE
  #109 (permalink)
Old 05-22-2007, 12:06 PM
I clamped a vise grip to the end of the axle and used that as a purchase point to pry the axle out enough for the snap ring to pop into place. Worked like a champ.
  #110 (permalink)
Old 05-22-2007, 02:47 PM
mgf250's Avatar
mgf250 mgf250 is offline
mgf250 is starting off with a positive reputation.
Are the four nuts securing the hub assembly completely tightened? Did you use a home made seal installer, you may have pressed just a tad too far?
__________________
02' F250 SD 4WD 5.4L V8 Supercab, 4.10 LS Heavy suspension.
  #111 (permalink)
Old 06-02-2007, 11:00 PM
Dirtfarmer69 Dirtfarmer69 is offline
Dirtfarmer69 is starting off with a positive reputation.
Ok guys, I followed all the directions and installed everything today. While I was testing everything, the truck makes some strange sounds while in 4wd. Everything went according to plan until it came time to install the knuckle seal. I used the homemade seal driver and may have sligltly deformed the seal. Is it supposed to seat perfectly flat? thanks.
  #112 (permalink)
Old 06-03-2007, 08:50 AM
I didn't feel too comfortable whacking the seal with the driver. IF I was to take the axles to the dealer, how do they get them on? I imagine that they have a jig that fits in the press.
Could I have bent the axles whacking the seal on there?
  #113 (permalink)
Old 06-03-2007, 02:43 PM
Kenwood Kenwood is offline
Kenwood is starting off with a positive reputation.
your doing something wrong if your concerned about bending an almost 2" axle made of hardened steel by installing a sheet metal stamped rubber surrounded seal. It doesnt take much to get the seal on the axle.. essentially all your trying to overcome is the Blue sealant... I used a regular hammer and about 5 hits and mine was on and flush..
__________________
Kenwood
2004 6.0 PSD 4x4 STD CAB 4WD
1987 Turbo GTA Trans AM
1995 Corvette
  #114 (permalink)
Old 06-03-2007, 02:48 PM
As far as the seal sitting flush it should be close.. I just referenced the factory installed depth..
Did you clean where the old seal was...as in knock the rust off with some light sandpaper.
Sounds like you forced it on when it was not square.. Usually I lightly tap the seal to get it started straight.. Then I hit it a couple of times hard and its on there..
As far as the noise goes.. Are you 100% sure that you got the SNAP RING in the groove in the axle??? I know that you have to pry the axle outward to expose the slot for the snap ring...
__________________
Kenwood
1995 Corvette
  #115 (permalink)
Old 06-03-2007, 03:46 PM
Thanks guys. Here is an update. I took everything apart and re-checked everything. Once back together, I spun the wheels off the ground by hand and found nothing wrong, so I took it on the road and no problems. The squeaks are 99.9% gone. I'm happy now. Thanks for the replies. I guess I was rushing while putting everything back together.
  #116 (permalink)
Old 06-09-2007, 10:54 PM
Want-A-Be 7.3's Avatar
Want-A-Be 7.3 Want-A-Be 7.3 is offline
Want-A-Be 7.3 is starting off with a positive reputation.
I started the ball joint replacement today, going well, took a little extra time as the best way to remove axel/seal, about 2.5 hours for right side for tear down learning curve, about .5 hour for left side once I knew how it goes, pressed out old ball joints and in new in machine shop at work (they have all the cool tools, hydraulic floor press, metal lathe, to turn correct size press drivers) that part gone smooth, reassemble Sun. or Mon.
  #117 (permalink)
Old 06-11-2007, 02:06 PM
Finished today and found the informaton onhow to be very usefull, thanks.
  #118 (permalink)
Old 08-14-2007, 02:50 PM
cudajim cudajim is offline
cudajim is starting off with a positive reputation.
Well, now its my turn to do this. I am trying to find the parts, what supply houses have the whole bundle in one Kit. I would like to upgrade the balljoints to ones that I can lube if possible.
__________________
Jim
2004 F250 Lariat 4x4 FX4 6.0 Diesel Crew Cab: ZooDad Mod, Butterfly Removed, EGR Unplug
2005 Chevy Avalanche, 1995 Ford Bronco Full size, 1994 Ford Explorer V6 295000 mi,
1996 Benz 300CE,1970 Plymouth Barracuda 440, 1996 Suzuki GSX1100G
1994 Bayliner 4788 Twin Hino 310hp Turbo Diesel W06DTII
  #119 (permalink)
Old 08-15-2007, 12:28 AM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a good reputation on FTE. biz4two has a good reputation on FTE.
Arrow
Quote:
Take a quick look at post #91. I am sure it was mentioned in other posts too, but I found it there...and stopped looking.
biz
__________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
1976 F150 LWB Custom 4x4 390FE NP435 3.50s
  #120 (permalink)
Old 08-15-2007, 01:34 AM
yamaguy's Avatar
yamaguy yamaguy is offline
yamaguy is gaining momentum as a positive member of FTE.
just subscribing
__________________
Dale PAA #47
03 F-350 XLT cc LB 4x4 7.3 psd 306,000 MI 9' 2" BOSS Ploy Vee
99 F-350 7.3 4x4 8'-5" Western
97 F-250 XLT Extend-cab 4x4 7.3 130,000
Tags
ball , change , f250 , f350 , ford , home , joint , joints , lube , made , press , removal , replacement , superduty , tight , torqued , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
