Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #61 (permalink)
Old 10-03-2006, 09:51 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold
You might damage them when you pull it apart but even if you don't they should be replaced anyway to prevent future, expensive damage.
It doesn't take much water and junk in the bearings to destroy them.
__________________
Dave - FTE moderator
Forum Guidelines
this space for rent
  #62 (permalink)
Old 11-13-2006, 08:32 AM
Kenwood Kenwood is offline
Kenwood is starting off with a positive reputation.
Just wanted to say thanks to racerguy...this thing was a lifesaver this weekend.. My lower RF balljoint was Wasted at 60K.. I followed these directions and they worked great.. Only thing I would add is BUY some extra pickle forks... I broke 1 trying to remove the lower ball joint..
It was nice though.. I used the NAPA Ball joints.. they even give you the PLUG for the upper zerk fitting..
Truck feels like new again..
__________________
Kenwood
2004 6.0 PSD 4x4 STD CAB 4WD
1987 Turbo GTA Trans AM
1995 Corvette
  #63 (permalink)
Old 11-13-2006, 10:11 AM
2002f2507.3LPS's Avatar
2002f2507.3LPS 2002f2507.3LPS is offline
2002f2507.3LPS is starting off with a positive reputation.
hey i only hear this cluck when i come to a stop mostly, and some times when i hit the brakes. safe to say its ball joints? im goin to go with the napa ball joints as well. and get brake rotors turned, new pads, slide pins for the callipers.
  #64 (permalink)
Old 11-13-2006, 12:12 PM
I never noticed any clunk or noise or anything out of mine.. What I did notice was excessive camber in the RF wheel and funny tire wear>>actually the tire wear led me to look at the camble angle..my UPPER was perfect but my lower was beyond trash..When I lifted the truck up and pulled on the top and bottom of the wheel I could feel it wiggle..
Ironically Brakes still had a ton of life left... Initially like yourself I decided While I had it apart Id do this and that.. well my brakes look like they could go about 60K more...
Oh the only other beware I can say is ..when making the seal press tool if you chose to make your own... Measure the flange.. My flange from Home Depot ended up being 4".. I spent about 15 minutes on a grinding wheel reducing the diameter to about 3.75" to fit the seal..
__________________
Kenwood
1995 Corvette
  #65 (permalink)
Old 11-13-2006, 02:22 PM
well as far as going over any bumbs i cant say i notice any noises out of the usuall, only hear the clunk when im stopping, or mostly once the truck has stoped it will do it. but i dont hear it any other time. nothing when excellerating from a stop. just when comming to the stop. but still ill have it jacked up tonight and ill wobble the wheel in all directions, see what it dose.
  #66 (permalink)
Old 11-23-2006, 02:17 PM
oldsw-31 oldsw-31 is offline
oldsw-31 is starting off with a positive reputation.
just did my 99 f350 and i wanted to add that all I i needed was a 21mm socket for all the hardware except for the Balljoints
i found this job to be real easy only took me 3.5hrs for the both sides . most of the time was spend cleaning the crap.
__________________
2005 Chevy 2500HD
1970 Oldsmobile W-31
1981 Olds Calais W-31 Clone
1957 T Bird 312 supercharged
1965 T Bird
  #67 (permalink)
Old 11-23-2006, 05:42 PM
Just did my 99 F350 and I wanted to add that all I needed was a 21mm socket for all the hardware except for the Balljoints which were a 28mm and 34mm
I found this job to be real easy only took me 3.5hrs for the both sides . most of the time was spent cleaning the crap.
__________________
2005 Chevy 2500HD
1965 T Bird
  #68 (permalink)
Old 11-25-2006, 07:44 PM
jetskiman6969's Avatar
jetskiman6969 jetskiman6969 is offline
jetskiman6969 is starting off with a positive reputation.
I have a question about the seals that are inside the axle tube near the carrier(on the front axle), there ARE seals in there, right??? Just wondering, how do I get them out, and HOW do I get new ones in there?? I didn't see this mentioned anywhere, so I'm a little concered because of the amount of gear oil I had dripping out of the axle tube. Thanks
  #69 (permalink)
Old 11-25-2006, 11:43 PM
need to remove the carrier and remove and install from inside the diff yopu need a spechial driver to install
__________________
2005 Chevy 2500HD
1965 T Bird
  #70 (permalink)
Old 12-06-2006, 07:25 PM
flkeysff flkeysff is offline
flkeysff is starting off with a positive reputation.
Hello I am new here and would like to say that is a very good write up on the ball joints, however I have one question what year vehicle did you do this on. The haynes manual I have state for 1999-2001 ball joint torque should be 101 lb-ft upper and lower and for 2002 models should be 63 lb-ft for upper and lower. Thanks
  #71 (permalink)
Old 12-06-2006, 10:25 PM
Racerguy's Avatar
Hi flkeysff and welcome to the forum
I don't remember what year the truck was that I used in the write-up. I do lots of thse so it becomes a blur.
It appears that Ford has changed the torque spec a couple times.
The Ford manual I have shows 101 lb-ft for both ball joints on a 1999.
The 2000 and up shows 150 for the lower and 69 for the upper.
I'm not sure why the change.
__________________
Forum Guidelines
this space for rent
  #72 (permalink)
Old 12-07-2006, 02:43 PM
Thank you for the reply, that makes me feel better that I torqued the ball joints correctly. I wish I had found your write-up when I had to replace mine it would have helped a great deal. but I managed without to many problems.
  #73 (permalink)
Old 02-26-2007, 06:07 PM
sdnomad sdnomad is offline
sdnomad is starting off with a positive reputation.
How do you diagnose bad ball joints on a super duty?
My F250 has 71,000 miles and it wanders while going down the rode. I was told the ball joints usually need replaced around 70,000 miles. How can I diagnose whether the ball joints are the problem? I saw it done once on another vehicle where they jacked it up and pried somehow on something but can't remember how it's done. I don't know if grabbing the tire and attempting to move it by hand to diagnose the ball joints is possible on something this heavy duty.
  #74 (permalink)
Old 02-26-2007, 06:40 PM
skuteman skuteman is offline
skuteman is starting off with a positive reputation.
.................Here is a question I have , In dec-'06 I had my whole front end rebuilt with new parts . Currently , it feels like it is alittle loose in the front end ! My sensory inputs are coming from the steering wheel . The truck had 99k miles when the work was performed and currently has 104k, so it has had alittle over 5k miles since the work was done . I've taken it back twice for an alignment check and something minor . The tech says everything is kosher but my steering wheel says othwerwise . I'm kinda at a deadend currently so my question is this.....Does\do the front ends on these trucks get alittle loose as we put over 100,000 miles on them ?? Logically , it would seem to make sense that any vehicle that accumulates lots of miles would just be somewhat more loose than a new truck . In other words , even using new parts is it inevitable that we cannot restore the precision of the frontend to what it was when New ??? thanks , skuteman
  #75 (permalink)
Old 02-26-2007, 07:40 PM
redford's Avatar
redford redford is online now
redford has a very good reputation on FTE. redford has a very good reputation on FTE. redford has a very good reputation on FTE. redford has a very good reputation on FTE.
No, if you replaced all the front end parts you should have a tight front end.
Your problem may be front tires (try rotating them) or your steering box may need adjustment.
__________________
2007 F-250 Super Cab Short Bed 4x4 XLT Sport Package 5.4L 3.73 LS Tow Command
Presently working as a military contractor in Afghanistan.
Tags
ball , change , f250 , f350 , ford , home , joint , joints , lube , made , press , removal , replacement , superduty , tight , torqued , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
