Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 12-30-2005, 02:35 PM
Bryanox Bryanox is offline
Bryanox is starting off with a positive reputation.
Hello,
I've got two questions concerning ball joints on my F250 Diesel.
When you change ball joints, is there a way to damage the speedometer cable?
The dealer who changed mine says no...but that is because I am accussing him of doing so. My speedo worked when I took my truck in to get the L side lower and upper ball joints changed. When I got it back the speedo would not work until I would get to around 35 mpg. When I was going about 35 the spedo would say 75. I had them check the wheel sensor but they said it was fine and that the problem was in the speedo head. I guess it could happen but I find it fishy.
I had the local ford dealer change L side upper and lower ball joints because they were wore out. Should I go ahead and change the R side too?
Thanks
Bryan
  #32 (permalink)
Old 12-30-2005, 02:58 PM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a good reputation on FTE. biz4two has a good reputation on FTE.
[quote=Miescha]
Quote:
I made my own seal press for the large knuckle seal using 3 steel pipe pieces from lowes - $15.26 total amount spent and 3 minutes to assemble pieces.
Miescha -- Good list of the parts and part #'s. Appreciate you sharing that information!
One question: Do you have a picture that you can share of the seal press that you made from lowes? I did see another picture (here in the thread), but would like to compare your seal press.
Thanks!
biz
__________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
1976 F150 LWB Custom 4x4 390FE NP435 3.50s
  #33 (permalink)
Old 12-30-2005, 03:12 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold
Hi Bryanox and welcome to the forum
Your speedometer doesn't use a cable. It uses a reading from the VSS (Vehicle Speed Sensor) on the rear axle housing...no where close to the ball joints.
__________________
Dave - FTE moderator
Forum Guidelines
this space for rent
  #34 (permalink)
Old 12-30-2005, 03:34 PM
OK. Thanks Dave.
Bryan
  #35 (permalink)
Old 12-30-2005, 06:10 PM
Miescha's Avatar
Miescha Miescha is offline
Miescha is starting off with a positive reputation.
Bad Wheel Bearing
Biz: Thanks for the compliments. I have taken from this site much more than I can probably ever give back - so I'm happy to help when I can. The parts-finding process was more difficult for me than the actual mechanical side!
As for a pic of the press I made, I tossed the thing when I was done without taking a pic. HOWEVER, someone else sent me a PM regarding it and I explained the parts I used and they are making one this weekend. I asked that they take a photo and send it to me so we can add it to the site. Hopefully we'll have it next week.
Finally, someone sent me a PM asking how I knew my passenger side wheel bearing was shot when I took it out. I don't recall who sent the PM, but hopefully they will read this. Below is a photo of the bearing race. NONE of the damage was caused by my removal - all the loose pieces fell out when I removed the hub assembly. YIKES!
__________________
1999 F-350 Lariat
4x4 CC 7.3L PSD SRW LB
St. Louis, Missouri
FTE Missouri Chapter Member
  #36 (permalink)
Old 01-12-2006, 01:33 AM
hink10's Avatar
hink10 hink10 is offline
hink10 is starting off with a positive reputation.
Miescha's homemade seal driver pic
Thanks to all for the ball joint replacement instructions, especially Racerguy for the write up and Miescha for the seal driver idea. After he described the driver, I knew exactly what he was talking about. Went to Lowes and purchased these parts:
1. 1 1/4" x 8" galvanized pipe
2. 1 1/4" flange
3. 1 1/4" cap
It was very easy and worked like a charm! Here is a pic.
__________________
03 4x4 Excursion XLT, 7.3 PSD
WW, 4" MBRP, DP Tuner 6 pos., BTS VB, HPX, Reg. Fuel, in tank, pre-pump, CCV, Gauges, boost reg., Trucool, trans filter, coolant filter, SPEARCO intercooler, Hellwig sway bar, Radius-rods, Air bags, Silverstars/wiring harness
  #37 (permalink)
Old 01-12-2006, 11:37 AM
Miescha's Avatar
Yep - that's it! Nice job deciphering my cryptic description. The parts cost me about $15 which I assume is about what you spent.
Glad to hear it worked as well for you as for me. However, I don't know that I'm the first to use this method. I just spent some time wandering around Lowe's looking for something that would work (I started in the electrical conduit area, then to fencing post area, then to plumbing and voila!).
Nice pic in your gallery too (mind if I steal it to show others?).
__________________
1999 F-350 Lariat
St. Louis, Missouri
  #38 (permalink)
Old 01-12-2006, 09:57 PM
hink10's Avatar
Here's the pic again
Here is the pic, obviously it didn't work in last post. Feel free to use the picture as you wish, thanks again!
__________________
  #39 (permalink)
Old 01-13-2006, 01:08 AM
Fat Diesel's Avatar
Fat Diesel Fat Diesel is offline
Fat Diesel is gaining momentum as a positive member of FTE. Fat Diesel is gaining momentum as a positive member of FTE.
I've found that 3.80 inches is a good diameter for the flange to drive the seal well. It can be smaller, but any bigger and it'll interfere.
__________________
Andy
Early 99 F250 PSD 4x4 CC 6spd ----- CCV Mod, 6637 Filter, DP Tuner Chip, ITP Fuel Sys, Dahl Filter, Cat Delete, BD 4" Cat Back, 203* 230,000+ Miles
  #40 (permalink)
Old 03-05-2006, 08:25 PM
FortyFords's Avatar
FortyFords FortyFords is offline
FortyFords is gaining momentum as a positive member of FTE.
TTT.If this is not in our info post at the top.I will get Monsta to put it there if he can.
Rich
__________________
" All levers like real trucks should be!" "Cool enough for me!"
" BSEG CLUB" 10 Strokin and 4 Smokin!
  #41 (permalink)
Old 04-04-2006, 09:00 PM
BolderKeith BolderKeith is offline
BolderKeith is starting off with a positive reputation.
Exclamation
Just did a ball joint replacement on a 2000 F-250 Super Duty 4WD. Made extensive use of Racerguy's step by step procedure with great color pictures of most of the important steps. I tried several home garage methods of installing the KNUCLE SEALS: PVC pipe and C-clamps on each side, etc without success. I finally went to a Ford dealer where they had a seal driver designed for this seal, and paid them $20 to install them. But I figured that I got $20 worth of advice from the mechanic. He said, after the seal is installed on the axle, slip axle with seal through the knucle, and then slip the four hub studs through the knucle, and draw the axle and seal into place by tightening the four nuts in small increments to keep things straight. It worked like a charm, and I did not need to do any pounding which I do not like to do on anything. I thought about having an installation tool made, but I suspect that it would cost at least $20.
  #42 (permalink)
Old 04-04-2006, 11:26 PM
Racerguy's Avatar
Quote:
I've never thought about doing it that way.
Not a bad idea
__________________
Forum Guidelines
this space for rent
  #43 (permalink)
Old 05-07-2006, 09:48 PM
mostoyzwinz mostoyzwinz is offline
mostoyzwinz is starting off with a positive reputation.
nice instructions racerguy...a big help. here's what i learned from doing my rusted front axle bj job. 1. the hub bearing assembly mounting studs were very rusted into the knuckle. side one took me four hours, a hot wrench, gear puller, and a 12 pound sledge....likely trashing the bearing in the process. so, how did i do side two? take the four nuts off, spray with penetrating oil, install nuts flush with top of studs, and use an impact driver, alternating between studs, and the second side was off in 30 minutes. i gave 'murph' at brewster ford in brewster, ny $20 for this valuable info. 2. pulling the axle seal assembly through the knuckle proved equally frustrating. after reaching through the back side with a screwdriver to push the seal lip into the knuckle, the axle seal assembly came out much easier. i'll post this in a new thread i'm gonna start on a separte axle bearing question.
  #44 (permalink)
Old 05-07-2006, 11:00 PM
TARCHER TARCHER is offline
TARCHER is starting off with a positive reputation.
nice instructions
Hey Racerguy, I'm no mechanic but like to mess around. Those are some of the best instruction with pictures I've seen. Great job. Love this site for outstanding info. Will no doubt save a guy a ton of $ not to mention the satisfaction of doing some of this stuff by self. Thanks....Tim..Prince George BC
  #45 (permalink)
Old 05-07-2006, 11:50 PM
Racerguy's Avatar
Thanks Tim
If you need your ball joints done and don't feel like doing it yourself just drive to Terrace and we'll set you up. lol
__________________
Forum Guidelines
this space for rent
Tags
ball , change , f250 , f350 , ford , home , joint , joints , lube , made , press , removal , replacement , superduty , tight , torqued , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
