Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #421 (permalink)
Old 09-01-2009, 11:17 PM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
If you torqued to specs you will be fine.
__________________
Brent Bradley Scenic photographer and former mechanic with car and motorcycle drag racing background. Also, avid snowmobiler.......retired. The Ex; custom mudflaps
  #422 (permalink)
Old 09-02-2009, 09:47 AM
brian42's Avatar
brian42 brian42 is offline
brian42 has a very good reputation on FTE. brian42 has a very good reputation on FTE. brian42 has a very good reputation on FTE.
Quote:
Originally Posted by pipefitter73 View Post
Well I may have goofed there as I followed the tutorial to the letter. Upper Bj 69 ft/lbs, lower 150 and all the other values you quoted for everything else. Oh, and the tie rod at 52ft/lbs. The Bj's are made by Duralast and didn't have any paperwork specs. I hope I didn't screw up. The knuckle was as tight as hell when I torqued the bj's. I could barely move it to install the tie rod in place. Let me know what all of you think, Bill
My torquing instructions were very specific. I don't know what documentation your ball joints had but the Moog instructions were the same as the Ford requirements for OEM ball joints:
1. Torque the lower ball joint to 35 lb-ft.
2. Torque the upper ball joint to 69 lb-ft.
3. Torque the lower ball joint to 150 lb-ft.
I was able to move my knuckles by hand after I installed them. Many people talk about stiffness and that it takes a few thousand miles to break them in. So far I have had no problems.
__________________
THE MOOSE
2003 F-250 PSD 7.3 Lariat FX4 CC/SB, 4R100, 3.73LS, dual alternators with 188K+ Miles
AIH delete, In-Tank (ITP) and Harpoon Mod, SS HPX, 203F Thermo w/Billet Housing, FTVB, '08 Rear Diff Cover, Headlight Harness (GOS), Zoodad (King Style), 6637, Foil Delete, Engine/CAC boots (Dieselsite), Moog Ball Joints, BFG Mud-Terrain TA KM2 285/75-16
Real Men Redline Less Than 3500 RPM
  #423 (permalink)
Old 09-02-2009, 09:41 PM
pipefitter73's Avatar
pipefitter73 pipefitter73 is offline
pipefitter73 is starting off with a positive reputation.
brian42 I did the other side today and torqued them again to the tutorial. I installed DURALAST bj's and both sets didn't have torque specs. The parts store referenced them and said OEM ford specs. So the truck is all back together and it is amazing how it handles. I'm happy, tires are happy and I saved a lot of $$$. Thanks to Merc, brian42 and all the rest. I am very satisfied. Now to do the exhaust. Is there an area here for modifying/installing new/better exhaust? thanks again guys, bill
  #424 (permalink)
Old 09-02-2009, 10:11 PM
Mercury45 Mercury45 is offline
Mercury45 is starting off with a positive reputation.
theres lots of truck sites.... i dont know if i can mention them here or ill get in trouble ... some sites dont like to see the others mentioned... as for exhaust though... i did a cat back magnaflow on mine at first with pipes going right out the back, but then later dumped them right after the rear axle... i like it but really it did not do much for me other then a nice sound.... im saving up for a diesel conversion but thats not for some time kenny
  #425 (permalink)
Old 09-02-2009, 10:24 PM
What I want in exhaust is throaty and noise if I want to get on it. I just don't know where to begin. I have looked at a lot of stuff online and our local muffler shops. The shops have nothing I'm looking for and they would install something they don't offer, but for a premium price, plus no guarantees (which I understand) not their product. So, again the quest begins. I can do all the pipe work myself. I have all kinds of stainless pipe and can get whatever I need. Can I do what ever I want from the cat converter without hurting anything. I would use the same pipe diameters as I don't want to screw things up.
  #426 (permalink)
Old 10-01-2009, 10:35 PM
HipCatMacDaddio's Avatar
HipCatMacDaddio HipCatMacDaddio is offline
HipCatMacDaddio is starting off with a positive reputation.
awesome post!
Thanks for the awesome post. Unfortunately I'm at a standstill. the axle dustseal that the dealer gave me matches the part# that you have listed, but I'll be damned if it won't fit into my axle housing (tube). #F81Z-1S175-HCA. Although it does fit on the axle. --The O.D. seems to be either too large or to small--. I've already been back to the dealer once to confirm that it is the right part. I have also tried to match it up without it on the axle. Any help would be appreciated as right now I'm halfway though!!! 2004 f350 cc 4x4 6.0 srw sb
Thanks once more in advance.
  #427 (permalink)
Old 10-02-2009, 08:54 AM
bkvanbek bkvanbek is offline
bkvanbek is starting off with a positive reputation.
For mine the dealer needed the vin and called ford.
__________________
2003 F 350 XLT Sport 4x4 6.0L Diesel
Bank's Big Hoss with PDA
  #428 (permalink)
Old 10-02-2009, 10:32 AM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
2004 Ford F-250
1975StroppeBaja has a good reputation on FTE. 1975StroppeBaja has a good reputation on FTE. 1975StroppeBaja has a good reputation on FTE.
The axle dust doesn't really fit into the axle tube. It kind of just rides along the outside edge of it. It has a nice tight fit on to the axle but kind of just rides wherever it ends up when it comes to the axle tube. You're using the same part number I did on my '04 so it should be correct. Maybe you could post up a pic of what you're talking about..?
Is it this seal?
  #429 (permalink)
Old 10-02-2009, 02:11 PM
Thanks for the reply. That's the one in the pic. Just seems to me that $23 is a hefty price for a seal that does as much good as one I could cut out of an empty milk carton... I guess that's why it's called a 'dust' seal and not an 'oil' seal...?
  #430 (permalink)
Old 10-02-2009, 07:42 PM
KelVarnson KelVarnson is offline
KelVarnson has a great reputation on FTE. KelVarnson has a great reputation on FTE. KelVarnson has a great reputation on FTE. KelVarnson has a great reputation on FTE. KelVarnson has a great reputation on FTE.
You'll be even more P.O.'d when the thing basically disintegrates in ten or twenty thousand miles. I am not a big fan of this design. I have decided that the surface where the seal rides on the axle tube will be a spot I regularly grease.
__________________
'02 F250 SCLB 7.3 4WD, 105k. 6637 Filter, JW Valve Body, 6.0 Trans Cooler, 285/75 16 Michelin LTX-AT2's, Line-X, Snug-Top Shell, Yakima Racks.
  #431 (permalink)
Old 10-02-2009, 09:07 PM
Ok, I installed the axle and tightened the hub to specs and now I see that it does just get drawn tight to the outside of the housing tube.--- 'dust' seal just about says it all. thanks everyone for the timely help. Anyone who goes out of their way to help a complete stranger (even if just replying to a thread) is a saint in my book.
  #432 (permalink)
Old 10-03-2009, 11:52 PM
GUNNERDOG GUNNERDOG is offline
GUNNERDOG is starting off with a positive reputation.
Just finished up installing new ball joints and hub on passenger side. Couldn't have done it without Racerguy's instructions.
Good stuff.
__________________
Justin -- 2003 F-250 SuperCab 4x4 V10 3.73's FX4 w/2008 bed
Trying REALLY hard to keep it stock.
Current project list: New steel brake line to rear end (rusted), Drill and lube locking hubs to try to get them unstuck, body work (minor rust/chip painting).
  #433 (permalink)
Old 10-08-2009, 02:09 PM
Nico Industries Nico Industries is offline
Nico Industries is starting off with a positive reputation.
How to install B. Joints on a F-150 2wd
I have my brother coming over tomorrow morning to install new ball joints on his 2000 F-150 XL, 2WD. I've done B. Joints on my Chevy Blazer in the past, but that was years ago. I'm mechanically inclined, so, I really need a step by step with pictures if anyone out there has the time.. Please email me at wayne@bowwowbonz.com
He's coming over tomorrow morning..
Many thanks in advance..
  #434 (permalink)
Old 10-10-2009, 09:30 AM
Chaos 6 Superduty Chaos 6 Superduty is offline
Chaos 6 Superduty is starting off with a positive reputation.
Okay...so I destroyed an expensive outer seal trying to get it on.
Anyone live in the Seattle (Issaquah) area with a seal driver that can help?
I can do the rest......but #$!@$ I knew better. That's what happens when I work too late into the night. I make stupid choices.
Need to get the pickup on the road.....Hunting Season is coming next weekend and it's tough to go when the Pickup is lame with a broken leg.
PM me and let's see if I can meet you to borrow the seal driver or give a little cash to have you install.
Thanks,
Mark
  #435 (permalink)
Old 10-10-2009, 02:47 PM
ironmine ironmine is offline
ironmine is starting off with a positive reputation.
Did you make the home made seal driver, but did not have good luck with it?
Thanks,
Mark
Tags
ball , change , f250 , f350 , ford , home , joint , joints , lube , made , press , removal , replacement , superduty , tight , torqued , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
