Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 03-30-2005, 11:11 PM
dagwood41's Avatar
dagwood41 dagwood41 is offline
dagwood41 is starting off with a positive reputation.
alls well except the wallet
Its is done and it even works. Ball Joints, o-rings and seals $230.00. Borrowed a seal driver from a local trucking company (If I ever do it again I will just buy one) which looks just like the one in the pictures. 3 1/2 hours to tear down and clean everything up and 3 1/2 to put it back together, took my time and checked everything. Then I went and did the easiest thing on the truck there is, put rear rear disc brake pads on. That was easy about 40 mins, took longer to get the tires and wheels off and on than it did to put on the pads.
Thanks again Racerguy for your words of wisdom.
Rick
__________________
Rick
2008 F250 CC/SB 4X4 6.4 PSD auto
1996 Allegro Bay MH 460 Ford
84 Mustang GT 605 BBF / Glide
http://i237.photobucket.com/albums/f...tes050-1-2.jpg
  #17 (permalink)
Old 03-31-2005, 12:14 AM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold
Good to hear that you got it done
Any other tips you'd like to add to the instructions here?
__________________
Dave - FTE moderator
Forum Guidelines
this space for rent
  #18 (permalink)
Old 03-31-2005, 07:55 AM
tazer tazer is offline
tazer is starting off with a positive reputation.
to dagwood Have you seen seal drivres commercially available like the one in the picture if so I am interested as sooner or later I will have to do it again.
  #19 (permalink)
Old 03-31-2005, 05:24 PM
dagwood41's Avatar
seal driver
rlkern
They are available any where they sell semi brake shoes and parts or any big truck dealership can set you up with one.
__________________
Rick
  #20 (permalink)
Old 04-02-2005, 08:37 PM
dagwood thanks
  #21 (permalink)
Old 07-21-2005, 10:31 PM
kbodge kbodge is offline
kbodge is starting off with a positive reputation.
Racerguy, first off let me say thanks great instructions, I used them to tear down my whole front end, replacing the seals, ball joints, axle suport bearings (reason I had to tear it down) etc.. I am trying to clean out the axle tubes and was wondering if you had any pointers on what works best to do this and also on installing the axle back through the tube so it dosn't pick up any grit from the tube. Thanks, any info would be greatly appreciated.
Kev
__________________
99 F250 SUPER DUTY 4X4, S/C, V-10
  #22 (permalink)
Old 07-22-2005, 01:09 AM
Racerguy's Avatar
You're welcome
What we use at work for cleaning out the tubes is a piece of pipe with half of a big washer welded to the end of it. You can put the pipe into the tube with the 1/2 washer facing up so it doesn't push the junk in further. Then with the pipe in the tube you twist the pipe so the washer is down and drag the junk out of the tube.
__________________
Forum Guidelines
this space for rent
  #23 (permalink)
Old 07-22-2005, 03:19 AM
ryaneverk2's Avatar
ryaneverk2 ryaneverk2 is offline
ryaneverk2 has a great reputation on FTE. ryaneverk2 has a great reputation on FTE. ryaneverk2 has a great reputation on FTE. ryaneverk2 has a great reputation on FTE. ryaneverk2 has a great reputation on FTE.
What great instructions. I'm saving this all in a Word document for future reference. Thanks a lot, Dave.
PS - why isn't this a sticky in the FAQ or something?
__________________
Ryan Arthur
* Sold * 2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat
ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator/tee, ATS housing, BBHA, CCV Mod, SS HPX, DP-Tuner, BTS-VB, lots of LEDs, and more...
My Truck Pics
  #24 (permalink)
Old 07-23-2005, 11:28 AM
Big Sky Big Sky is offline
Big Sky is starting off with a positive reputation.
Thanks for posting this. I copied it onto word, photos and all as well.
__________________
2002 PSD Excursion Limited 4x4, Mineral Grey. Hellwig Anti-Sway Bar.
2000 F-250 SC 4x4 V-10, Burgundy, Raven Topper
  #25 (permalink)
Old 07-24-2005, 12:13 AM
Hootbro's Avatar
Hootbro Hootbro is offline
Hootbro is starting off with a positive reputation.
Good Information.
  #26 (permalink)
Old 12-01-2005, 03:31 PM
GummyF250 GummyF250 is offline
GummyF250 is starting off with a positive reputation.
Part numbers
Anybody know the Ford part numbers for the hub o-rings,axle seals,dust seals and any other parts I might need to service the spindle needle bearings.My truck is a '04 f250. Thanks in advance if anybody knows.
  #27 (permalink)
Old 12-12-2005, 09:52 PM
Miescha's Avatar
Miescha Miescha is offline
Miescha is starting off with a positive reputation.
Post Part #s and Prices
Ok, I finished my front end project and it took as long to find the parts as it did to complete the project (about 6 hours each - I worked slow and spent A LOT of time cleaning parts). For those wondering, I am not a mechanic (though I am mechanically inclined) and I have never touched this truck or any other Ford vehicle in the past. I didn't know what a ball joint, knuckle, U-joint, axle stub, or thrust washer was when I started. A huge thanks go to Racer and Fortyfords for their help throughout the project (and after).
Following is what I know regarding part numbers and prices - I hope this helps others avoid the same pain I endured finding parts. Everything I know is listed below - if it is not listed, I do NOT know. I used all Ford parts except the ball joints - I used NAPA for these. I'm told Ford now has greasable ball joints, but none of the dealers who gave me part numbers had them in stock.
Also, my 1999 F350 4x4 is a 1999.5 (I was just told that may make a difference in the parts needed - I'm happy to have the 'edit' button when posting).
Wheel Bearing:
Ford # C6tZ-3123-A $9.30 each
NAPA # B2110 $6.42 each
Small Knuckle Seal or "Dust Seal"
Ford # F81Z-1S175-HCA $15.46 each
NAPA # 21918 $8.99 each
National #710413 $7.84 each
Large Knuckle Seal or "Oil Seal" (pressed on with special tool)
Ford #F81Z-3254-CB $26.54 each
NAPA N/A N/A
Hub Assembly Seal (small yellow seal)
Ford #F81Z-4A322-AA $3.48 each
NAPA N/A N/A
Upper Ball Joint
NAPA #260-1248 $30.44 each
Lower Ball Joint
NAPA #260-1395 $48.69 each
Auto-Lock Hub
Ford #1C3Z-3B396-CA $279.00 each
I purchased my auto-lock hubs on ebay (new - still sealed in plastic) for $250 with shipping. My Ford dealer wanted $558.32 for the pair. Either way, the new hubs came with new o-ring seals, so I didn't need to buy these (and don't have numbers or prices). If my math is correct, this brings my total parts cost to $517.00 (my dealer wanted about $1,500).
For the ball joints, I "purchased" a press kit from Autozone for about $110, but it really works as a deposit. I returned the kit the next day (although they said I could keep it for up to 90 days) and they fully refunded my money to the last penny - a free rental in the end.
I made my own seal press for the large knuckle seal using 3 steel pipe pieces from lowes - $15.26 total amount spent and 3 minutes to assemble pieces.
I hope this helps everyone else doing this job.
__________________
1999 F-350 Lariat
4x4 CC 7.3L PSD SRW LB
St. Louis, Missouri
FTE Missouri Chapter Member
  #28 (permalink)
Old 12-12-2005, 10:15 PM
vancouverpower vancouverpower is offline
vancouverpower is starting off with a positive reputation.
Good job on the write up! Can you put this in the articles/specs area at the top of the page so it can be found fast later? Thanks again.
__________________
1999 psd f250 4x4 super cab xlt six speed, bullydog chip, 4" downpipe, 5" straight pipe, kwik filter, level lift kit 35" bfg's, blackcloud diesel ebpv exhaust brake.
  #29 (permalink)
Old 12-12-2005, 10:19 PM
Miescha's Avatar
Racer's write-up really is awesome (it is what motivated me to even try the project with no prior experience). Maybe one of the moderators can figure out how to make this easy to find.
Also, Fortyfords has a ton of knowledge in this area and always seems happy to help.
__________________
1999 F-350 Lariat
St. Louis, Missouri
  #30 (permalink)
Old 12-30-2005, 11:56 AM
hink10's Avatar
hink10 hink10 is offline
hink10 is starting off with a positive reputation.
Where to buy ball joints?
I picked up some ball joints at AutoZone, pretty good price. Anyone know if they are good quality, or should I go to Napa? Thanks.
__________________
03 4x4 Excursion XLT, 7.3 PSD
WW, 4" MBRP, DP Tuner 6 pos., BTS VB, HPX, Reg. Fuel, in tank, pre-pump, CCV, Gauges, boost reg., Trucool, trans filter, coolant filter, SPEARCO intercooler, Hellwig sway bar, Radius-rods, Air bags, Silverstars/wiring harness
Tags
ball , change , f250 , f350 , ford , home , joint , joints , lube , made , press , removal , replacement , superduty , tight , torqued , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
