Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #226 (permalink)
Old 11-07-2008, 12:45 AM
westvandude westvandude is offline
westvandude is starting off with a positive reputation.
I ordered the kit from powerstrokeshop.... Powerstrokeshop.com $291usd plus s&h. I bought an oil filter and fuel filter at the same time.
Local parts store (Lordco Auto Parts Ltd. - British Columbia's Source for Auto Parts) wants $300cdn a side for the parts. Ya right. Jokers.
Originally had a clunk sound in front end a second after hitting the brakes. Ended up finding a leaking tie rod boot in the driver's side, replaced that. Still had a clunk sound (not as bad). Then I pulled the front driver's side tire, was able to wiggle the whole knuckle/hub up and down 1/8" and looked behind to see lots of play in lower ball joint.
Bad timing.... should be a month or so till my new workshop is framed up but I don't think those lower ball joints will last. Thinking maybe replacing the lower BJ without opening the hub up. Can you replace the lower without disturbing anything else? Using the c-clamp press?
  #227 (permalink)
Old 11-07-2008, 06:18 AM
Mercury45 Mercury45 is offline
Mercury45 is starting off with a positive reputation.
i doubt you will be able to do just the lower ball joint - the reason i say that is cause you need to remove the knuckle to get the lower ball joint out... to remove the knuckle the upper ball joint has to be banged out of the (i will call it the frame fork) this holds the knuckle. by the time you are done beating the upper ball joint - you will need a new upper too
kenny
  #228 (permalink)
Old 11-30-2008, 07:27 PM
vento vento is offline
vento is starting off with a positive reputation.
Mercury45 is correct. the amount of work involed to do just the lower ball joint, you might as well do them both. The upper might be ok if you use the press to remove it, but it has already been stressed due to the lower being bad. If your going to pull it apart save your self some aggravation and do them at the same time.
  #229 (permalink)
Old 11-30-2008, 07:37 PM
Quote:
Originally Posted by vento View Post
Matco Tools sells that seal driver for about $75.00 the Part#: MST6695. Matcotools.com
or you can make one out of some black pipe ??
kenny
  #230 (permalink)
Old 12-14-2008, 09:32 PM
brodiedehass brodiedehass is offline
brodiedehass is starting off with a positive reputation.
Seal Driver Not Needed, How To Install Vacuum Seal Without Seal Driver Super Duty
Hey Guys,
I used the original posters how to for a couple of Superduty (Mine were 01 & 04 models) ball joint jobs. It work well for me but I figured out a way to install the axle vacuum seal without using a seal driver. I have used this method several times with great success.
1.Put a wheel upside down on the floor,
2.Set the hub assembly on top of the wheel,
3.Set your new vacuum seal correct side up on top of the hub assembly, (i not the fist time, ruined the seal )
4.Put the axle shaft through the hub Assembly,(make sure the shaft is clean)
5.Use the axle as a slide hammer, make sure it gets started evenly, pull the axle up some (not out of the hole) and slam it down, feel free to use a soft hammer to tap on the axle
Putting the Axle back on the truck:
I did the same thing as the original poster to put the axle back on the truck,
I wiped it clean and installed it in as far as I could myself.
Install the flat well greased washer with the groves towards the inside
Put some grease on the axle shaft where the needle bearing from the hub assembly will be riding
Install the hub assembly and start the studs and nuts,
Tighten the nuts evenly to push the axle back in correctly.
PICTURE OF METHOD SETUP:
http://i24.photobucket.com/albums/c4...ety/img093.jpg
  #231 (permalink)
Old 12-14-2008, 10:07 PM
mblanken881 mblanken881 is offline
mblanken881 is starting off with a positive reputation.
If anybody needs the parts to replace your ball joints on one side of you Super Duty, I had the parts for both sides but after doing one side decided to have the other side professionally done and they wouldn't use my parts. I will give you a great deal just to get them out of my garage. I have everything you need not just the ball joints - seals included. Mike.
  #232 (permalink)
Old 12-14-2008, 11:09 PM
Thumbs up Seal Driver Not Needed, How To Install Vacuum Seal Without Seal Driver Super Duty
Hey Guys,
3.Set your new vacuum seal correct side up on top of the hub assembly, (i did not the fist time, ruined the seal )
I did the same thing as the original poster to put the axle back on the truck,I wiped it clean and installed it in as far as I could myself.
  #233 (permalink)
Old 12-19-2008, 12:09 AM
chevypc's Avatar
chevypc chevypc is offline
chevypc is starting off with a positive reputation.
I am new here. This was a great help. I installed a new front axle U-joint just in time for the 12" of snow will get tomorrow. I have changed many in older trucks, but never in a Super Duty. I plan to visit this site often. I have owned Ford F250s since 1978. After the "Blizzard of 78" I said that I would never go through another winter without a four wheel drive.
  #234 (permalink)
Old 12-25-2008, 04:01 PM
tumbleweed2's Avatar
tumbleweed2 tumbleweed2 is offline
tumbleweed2 is starting off with a positive reputation.
I am 50/50 of doing this myself. I took apart and found stub axle flange was rubbing back face of bearing assy. (Worn/dry axle support needle bearings.) So I purchased all parts to do swap. But I wonder If I should replace stubaxle to, or is there a thrust washer between the two that was actually rubbing? It was hard to tell with all the old dustseal particles. The axle race seemed smooth.
If I do this myself,
What is the chance of the camber (little sleeve like inserts?)getting out of wack when changing the ball joints?
How can I tell If I need a new axle other than to compare it to a new one?
thanks for all the great write ups and pictures and tooling Ideas,
Ryan
__________________
Ryan
01' F-250 PSD 4x4
4'' turbo back, 4'' lift, 35's, 4.10 gears, ZOODAD, 08' diff cover, DP tuner, gauges, tranny cooler, 200K+ miles, ...
  #235 (permalink)
Old 12-28-2008, 12:55 PM
Ryan
If nothing looks worn on the stubaxle you should be fine. I would definately replace the thrust washer. It is plastic and will wear before the other parts will. Are the three washers and snap ring on the outer in the the shaft worn(thin or grooved)? If they are replace them too.
The camber sleeves are mounted loosesly when the balljoints are out. There is a great chance they will be out of adjustment when you put it back together. Even your new ball joints could be a little different than the old ones. The to avoid the tire wear the alignment is worth it.
  #236 (permalink)
Old 12-30-2008, 08:14 PM
Hey Brodiedehass, thanks for the info. Turns out axle was worn (I compared the drivers side.) the bearing race is larger o.d. than the rest of the shaft.
I was reluctantly dropping truck off at the dealer and they said it wouldent be ready for a few days, So I grabbed my keys and left....
I DID IT! all ball joints, new hub assy, warn hubs, seals and new axle. I just went ahead and ordered a hole new passenger axle. Axle was pricey but it came with all the seals.
The galvanized pipe seal-tool worked great. I did turn the face flat on a lathe. but not necessary just spin it around as you hit it.
So, why does the dealer charges over 3hrs $$$ per side when I just did one side (tire off to tire on) in exactly one hour taking my time? (new hub,bearing assy, and axle)
I dont want to RANT about labor charges and the rising cost of parts, but I AM.!! Dang it!
Sorry for all the wind, I'm just amped that I did it and did it right(i think).
THANKS TO EVERY SINGLE PERSON THAT MADE THIS THREAD!! THIS SITE ROCKS.
__________________
Ryan
01' F-250 PSD 4x4
  #237 (permalink)
Old 01-24-2009, 09:33 AM
slim pickens slim pickens is offline
slim pickens is starting off with a positive reputation.
I just finished the ball joint replacement on my 2000 4x4 Ex. WOW. It took me quite a while, prob about 10 hours, but a lot of time was wasted by not having the right tools the first time. This note is to help anyone doing ball joints on an Excursion, F-250 SD or F-350 SD.
1. the autozone pickle fork (loaner part no. 27020) is too small. It works for the tie rod ends, but is not wide enough for the ball joints. Get (2) of their 27021 Pitman Arm pickle forks, they are wide enough for the massive ball joints on an excursion/super duty.
2. Print out the directions that Racerguy put together on here. I spent plenty of time going back in the house to check torque values, etc.
3. The " oil seal" aka Axle/Knuckle seal installation tool is a must, but make sure the flange is square to the pipe. I have a lathe so I trued mine up, but they are just crappy chinese pipe fittings so mine were WAY out of square. I dont know what the consequenes would have been if I tried to drive them on with an out-of-square driver. See item 4.
4. The axle-knuckle "oil seal" seals are a 0.010 inch interference fit at ~2.5 inch diameter(!!!) A typical interference (press fit, shrink fit) is along the lines of 0.001-0.002 inch per inch of diameter. Basically this is a humongous interference fit. This also means unless you have a 5 lb hammer and can swing it like Paul Bunyan, you need a bigger hammer. I never saw this mentioned in any of the write ups. I tried for a LONG time to fit these on using a regular hammer, tried grinding the lip to lead it in, and only after I measured it (I thought I might have the wrong part?) I realized I needed a REALLY BFH. I whaled on it about 8-10 times with a 5 pound sledge to get them seated. That was WAY more than I was expecting. I felt like I was driving railroad spikes.
5. The typical ball joint press they have as a loner at autozone or advanced auto is damn near too small. Expect to make up some spacers and etc to get the job done. If you can beg/borrow a kit made for a heavy truck, that would work 100x better. I was extremely worried I was about to destroy the loaner press I got from advanced auto... and I was probably close.
6. After breaking a 33mm socket (thanks autozone chinese crap tools) I realized that a pipe wrench works great for removing stubborn ball joint locknuts (upper and lower). Pipe wrench highly reccomended. Stick a 6 foot lever pipe on the handle and those stubborn nuts crack like glass. Then use the crappy socket for installing the new ones, apparently they can handle 150 ft-lb. Barely.
All said and done, I would do it again since I saved about $800 in labor and it only cost me a weekend. I could probably do it in half the time next time. Here's to another 95k!
After the new ball joints and an alignment, my party bus drives like new. It is amazing how much difference it makes. My old ball joints had .050 play on the driver lower and 0.125 play on the passenger lower. The uppers were fine.
I hope this helps some people.
  #238 (permalink)
Old 01-24-2009, 05:20 PM
3000 FPS's Avatar
3000 FPS 3000 FPS is offline
3000 FPS is starting off with a positive reputation.
Quote:
Originally Posted by SGnAZ View Post
Can you tell me where you got the vacuum line nipples? My Ford dealer doesn't know what I'm talking about.Thanks
I took out the old nipple and compared to the selection that they had at the Napa auto parts. They had a big selection of brass nipples there for vacume lines.
__________________
01 F250 4X4
05 F350 CC 4X4
Slammed 54 buick
  #239 (permalink)
Old 01-25-2009, 11:37 AM
ironmine ironmine is offline
ironmine is starting off with a positive reputation.
Quote:
The last time I did balljoints, my local Advanced Auto now had a larger, expanded Balljoint Press Kit for loan --- which included the proper SuperDuty cups/spacers.
I guess it depends on the individual Advanced Auto.
I feel kinda bad borrowing tools like that from them since I buy my parts at NAPA. So I buy my fluids, filters, supplies from them.
  #240 (permalink)
Old 01-31-2009, 10:50 PM
chrisrummy chrisrummy is offline
chrisrummy is starting off with a positive reputation.
what a great write up. i am reaplacing my inner axle seals, cause there leaking and was wondering if ill need any special tools to put them back in with or do they just get taped in?
Tags
ball , change , f250 , f350 , ford , home , joint , joints , lube , made , press , removal , replacement , superduty , tight , torqued , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
