Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-10-2005, 12:14 AM
curtioso curtioso is offline
Garage is empty, add now
curtioso is starting off with a positive reputation.
Propane conversion for 460
I have an 89 F350 crewcab that I want to convert.
Does anyone know the cost and best way to go about converting a 460 from gas to propane?
Thx
  #2 (permalink)
Old 03-10-2005, 12:58 AM
furball69's Avatar
furball69 furball69 is offline
furball69 has a very good reputation on FTE.furball69 has a very good reputation on FTE.furball69 has a very good reputation on FTE.
Yellow pages.
You will probably need to get it certified and any shop will likely not certify it without taking the tanks out and and re-valving them and pressure testing.
That all depends on whether or not you can find a place that will fill it without checking for a cert sticker, if you can get around that then you can do it yourself if that is your intention. In that case, to answer your questions; cost depends on how expensive the parts you buy are and really, the only decision on the actual conversion would be placement of the tank/s (in bed or under) and whether you want to keep it on gas or not, the rest is pretty cut-and-dry; Install tank/s, hoses, lockoff, evaporator, mixer, hose from evaporator to mixer, hoses from mixer to throttle body, hook up sending unit. * Install alternate fuel switch if you are going dual fuel... You'll also need to find a way to kill the injectors if you are going to run dual.
http://www.google.ca/search?hl=en&q=...on+parts&meta=
  #3 (permalink)
Old 03-10-2005, 01:35 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
Check the yellow pages for a Propane outfit. If they convert, they'll advertise.
$1500 will do ya. Tanks and carbs and all the hook ups. And also about 70% of the power you know have, finding fuel on the road will now be special project, and you'll come to love Marvel Mystery Oil.
Polish it up and trade it for a newer oil burner.
  #4 (permalink)
Old 03-10-2005, 11:49 AM
Thanks VERY much for the info, looking into what you suggested
Thanks again,
Curtis
  #5 (permalink)
Old 03-10-2005, 12:06 PM
therdt therdt is offline
therdt is starting off with a positive reputation.
I have a '97 F250HD 7.5L I did some extensive checking last year and found it to be about $2500.00 depending on the tank size. There used to be some tax incentives for the conversion but they might have expired in 2004. I have renewed interest in doing the conversion again since gasoline is climbing this season. Also I was lead to believe that in our fuel injected motors, the LPG would be supplied to the motor via the existing injectors and not via the air intake as in carb engines. Please post what you find.
  #6 (permalink)
Old 03-11-2005, 12:56 AM
furball69's Avatar
You might be able to find someone that makes a system with injectors as they do exist for a few models. Not sure about the 7.5. Mine is propane (carbureted) and fuel injected.
  #7 (permalink)
Old 03-16-2005, 08:35 PM
cornfeed cornfeed is offline
cornfeed is starting off with a positive reputation.
Why the marvel mystery oil? I am just curious
Thanks
__________________
1951 f5 239 flathead
1959 f100 4x2 223
1974 f100 4x4 390
1975 f150 4x2 390 4bbl
1978 lt800 dump truck 477
1989 f150 cummins 4bt
1993 f150 4x4 302
1997 f700 429 LP
2000 taurus 24v DOHC 3.0
Tags
1978, 1997, 350, 460, 86, conversion, converted, f150, f350, ford, gas, lp, lpg, propane, regulator, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
