Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Minnesota Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Minnesota Chapter Join Chapter, Leader: fordpower88
  #1 (permalink)
Old 03-09-2005, 08:07 PM
namxas namxas is offline
Garage is empty, add now
namxas is starting off with a positive reputation.
300-6 engine swaps
I'm curious to know what V8 engines I can swap for my 300-6 in my 78 F150. I have a 390 I can use, but I would have to change the bell housing, radiator etc. right?
Thanks,
josh
  #2 (permalink)
Old 03-10-2005, 08:17 AM
79 posi's Avatar
79 posi 79 posi is offline
79 posi is starting off with a positive reputation.
302 and 351 windsor have the same bellhousing.
302 only came in 2wd so would have to fab motor mounts if 4wd(actually doing this right now). 351 windsor didn't come in any 70's ford pickups so would also require some fabrication.
If you don't have either these it would probably be easier to get the 390 mounts and bellhousing and whatever wiring/accessories are needed.
Tags
300, 3006, 78, bellhousing, engine, ford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
