1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Max Speed in 4wd Hi
Old 03-09-2005, 06:43 PM
sportscar's Avatar
sportscar
sportscar is offline
Max Speed in 4wd Hi
I cant find the info in the owners manual or on this site. I know I have seen it somewhere. What is the max recommended speed while in 4wd Hi? As in hard packed snow on the hiway (other than good common sense)
04 F250 V10 3.73 Auto
Old 03-09-2005, 07:17 PM
wlihntr's Avatar
wlihntr
wlihntr is offline
i am pretty sure you can drive as fast as you want. when ever people run there trucks at the drag strip they run them in 4 hi and run up to aroud 100mph
Old 03-09-2005, 07:56 PM
SMiller's Avatar
SMiller
SMiller is offline
There really isn't any problem running high speeds in four high, as long as the front drive shaft is well balanced there is really no differnce, there would be a little more heat in the transfer case, but as long as it was slick out you would be ok, I wouldn't be afraid to run any speed in four high, but usilly if I can drive 50mph+ I am in 2wd anyways.
Old 03-09-2005, 08:47 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
If the road is slick enough for four wheel drive, you can drive way faster in 4x4 than you will want to go.
Harleyboy61
07-25-2015 02:12 PM
Tim66250
11-20-2014 05:47 PM
wd40slinger
02-12-2014 04:47 PM
TexasA&M
07-18-2011 02:41 PM
neilfromatl
09-21-2010 08:14 PM
Quick Reply: Max Speed in 4wd Hi
