Ride Height 4x4 dually?
If the entire truck is on a dead level pad when you are measuring the distance, it sounds like the springs are getting weak on the drivers side.
A spring shop should be able to fix you up for something between 3 and 5 hundred for both springs.
You do not say what year, but a friend of mine just picked up a set of X springs for his 2004 350 for about 350 dollars. That was just the springs, no hardware and not installed.
