Intake Manifold Coolant Leak - Ford Truck Enthusiasts Forums
Old 03-09-2005, 03:02 PM
woodya651 woodya651 is offline
woodya651 is starting off with a positive reputation.
Can the line from under the manifold be removed and plugged at the heater hose with no ill effect or will coolant run from the exposed port in the lower manifold? I cannot see where the coolant goes to, does it just sit in the manifold with no flow?
Old 03-11-2005, 04:07 PM
Bart99GT Bart99GT is offline
Bart99GT is starting off with a positive reputation.
I think that is the return for the heater core.
Old 03-15-2005, 07:34 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
If you are talking about the 3/8" or so line from the tee in the heater hose, it will leak if disonnected and left unplugged.
Think about it for a second. If it were to fail to leak, then where would the coolant be flowing? It could only come & go thru the hose. Not likely. It has to flow thru somewhere or it is useless.
tom
Go Back   Ford Truck Enthusiasts Forums > >
Tags
2007, 23, 23l, 30, 50, antifreeze, coolant, ford, intake, leak, leaks, manifold, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
