Help Carbed 2.3 not starting!!!!! - Ford Truck Enthusiasts Forums
Old 03-09-2005, 12:05 AM
Samsonitesamsonite's Avatar
Samsonitesamsonite Samsonitesamsonite is offline
Samsonitesamsonite is starting off with a positive reputation.
Cool Help Carbed 2.3 not starting!!!!!
Alright guys i have a couple questions..... there was a carb on my ranger that worked but had low power so i took it off and the reason it had no power was that the secondary was rusted shut anyway i got another carb that i know works and hooked up of the same way as the old one and i cant get it to start....... it seems to try but just wont do it....... the only lines i have hooked to the carb are the gas line and a vacuum line from the intake manifold to the passenger side of the carb..... the EGR was non existant on the old one so i didn't bother hooking it up on the new one either..... long story but it just wont work.... sorry for writing a novel here guys but i need some help pronto. Thanks!!!
Old 03-10-2005, 09:16 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
Check that you have fuel in the float bowl by opening the throttle while you look down the venturi. There should be a shot of gas as you work the throttle. If not, you don't have gas in the float bowl, or the accelerator pump is shot.
I'd also check for vacuum leaks.. loose hold-down bolts or bad carb gasket, PCV hose knocked off by some fumbling around. You know the drill.. look for what you might have bumped. Even the coil wire to the dist...
tom
Old 03-10-2005, 05:02 PM
thanks ill check that out and report back this weekend!
Go Back   Ford Truck Enthusiasts Forums > >
Tags
23, carbed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
