Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-08-2005, 06:01 PM
loneleader is starting off with a positive reputation.
Question Fuel Pump Relay??
'89 E350 with 351W.
Died. Towed home 2 times. Got spark to plugs. No elec to external fuel pump. No elec to inertia switch. Any idea where the fuel pump relay is in this rig? Or am I barking up the wrong tree? Have not tried to check power to intank pumps, I stopped when I checked external (on rail) pump.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-08-2005, 08:15 PM
mstarr is starting off with a positive reputation.
If you are not getting power to the inertia switch then you blew a fusible link. Check out this schematic, it is for an 85' truck but should still be the same on you van.
http://www.ddeboer.com/fordtruck/pag...20Tank_gif.htm
Most fusible links are within a foot or so of the starter relay, where ever that is on you van. It will look like a plastic block on the wire. Good luck.
__________________
85 F-350
460/7.5L
4-speed manual
4x4 Crew Cab
  #3 (permalink)
Old 03-08-2005, 09:59 PM
I am trying to incorporate the truck schematic with the Chilton engine schematic I have for '89 5.8L. It doesn't seem to make a lot of sense. What is the best way to test a fuseable link?
  #4 (permalink)
Old 03-08-2005, 11:14 PM
I am not familiar with the vans, but most things operate basically the same.
Anyway, a fusible link is just a smaller guage wire that will burn if there is to much current passed through it, the insulation block is there to keep it from starting a fire. You want to check the wire for continuity, use a volt meter or test light and make sure that the connection is not broken inside. I just strip a small amount of insulation on each side of the fusible link and touch the wire. You can also find the connetor at either end and check for continuity.
__________________
85 F-350
460/7.5L
4-speed manual
4x4 Crew Cab
  #5 (permalink)
Old 03-09-2005, 10:40 AM
Got it. Thanks!
  #6 (permalink)
Old 03-09-2005, 02:57 PM
Let me rephrase that, I don't got it. I could only find two fuseable links, one on the negative post that looks like it deals with my trailer/hitch stuff, and one that doesn't go to the fuel direction that is OK anyway. So, at this point, I am stumpped again. I have taken all of my dash apart tracing wires, but when they go into major harness, I lose them. Regardless, there are still only two fuseable links under hood. Is it possible that there could be some kind of junction that has a fuse in it?
  #7 (permalink)
Old 03-09-2005, 06:21 PM
I did some research and it looks like the vans are a little different then the trucks, sorry.
But you do have a fusible link that goes to your fuel system, it just might be deeper into the system and could still be the problem. It should be a yellow wire up to the fuel pump relay and then the power output wire to the inertia switch will be an orange wire with a light blue stripe. After the inertia switch there should be a pink wire with black stripe that powers the pumps.
Your pump(s) only get power when you are starting and then when the engine is running. Most engines have some sort of oil pressure shutoff switch, but I don't see one on this schematic (doesn't mean you don't have one for sure). It might be that your computer isn't sending the signal to the pcm power relay to tell the fuel pump relay that the engine is running.
Hopefully this picture works, if not, it should be the same wiring schematic as in your book. (I got it from the autozone website) Good luck
[img]file:///C:/Documents%20and%20Settings/Tina/My%20Documents/My%20Pictures/0900823d801775af.gif[/img]
__________________
85 F-350
460/7.5L
4-speed manual
4x4 Crew Cab
  #8 (permalink)
Old 03-09-2005, 06:24 PM
doesn't look like the picture worked, got to go figure that out. But you can see the picture if you go to www.autozone.com and on the left side click "repair info". You want to find your way to chassis electrical.
__________________
85 F-350
460/7.5L
4-speed manual
4x4 Crew Cab
  #9 (permalink)
Old 03-09-2005, 08:10 PM
racinrob is starting off with a positive reputation.
my 87 ev troubleshooter says check fuse link at starter relay. then check grounds are clean and tight at g112(lh side of dash panel) g203(on ground bus at left hand side of y brace). the last one grounds the fuel system i think. its hidden at the bottom of the LH y brace on its left side. hope this helps.
it mentions to check fuel pump relay but gives no location. the fuel pump cut off relay is on the left hand side of the dash.
  #10 (permalink)
Old 03-10-2005, 10:11 AM
86rustbucket's Avatar
86rustbucket is starting off with a positive reputation.
The fuel pump relay on my 91 E150 is on the inner fender on the passenger side. It is covered by a black plastic shroud that is bolted to the inner fender with two sheet metal screws. The shroud holds the EEC relay and Fuel Pump relay. The fule pump relay should have a green connector and the EEC relay should have a black connector.
I had the fuel pump relay go bad on my 90 F350, replaced it with the one from my van and it fired right up. I'd check the relays first if I were you.
The replacement fuel pump relay is < $10.00 at the parts store.
To be sure if they are working, you should be able to hear them clicking if you can have a helper turn the key (not to start, just ignition on).
If I remember, I'll try to take a picture of the relay tonight and put in my gallery.
  #11 (permalink)
Old 03-10-2005, 12:17 PM
pfogle's Avatar
pfogle is gaining momentum as a positive member of FTE.
THe relay will only have power for a few seconds when you turn the key. It has a prime function when the engine isn't running.
__________________
1992 E150, 351, 1 ton E4OD (RIP)
Courtesy of my WIFE: "Why do they call it 'scruff' when it's more like mini-daggers?"
  #12 (permalink)
Old 03-10-2005, 01:06 PM
Thank you all very much!
Not knowing what these relays did, but guessing, I have already replaced both of the relays mentioned by 86RUSTBUCKET. So that is not where the problem lies. I'm thinking that it could be in the PCM, (computer/brain). I can't find a fuse-link that connects to the fuel system, unless it's hidden behind the speedo-guage panel of the dash. I'm having a problem getting the speedo cable undone to check. However, if the problem is in the PCM, that would be much more easy to test. Does anyone know how to test it, or can it be tested??
  #13 (permalink)
Old 03-10-2005, 04:29 PM
OK, I just pulled code #95, which Chilton says, "Fuel pump secondary circuit failure -PCM to ground".. Where should I go from here?
  #14 (permalink)
Old 03-10-2005, 08:26 PM
fordfuelinjection.com has alot of info on codes and eec info. they say code 95 "infinite ground" sensed by the eec from the fuel pump. i think there is a ground at the in-tank pump that can come loose. worth a shot if you've check everywhere else. i remember a post were someone while replacing a fuel pump noticed the ground was loose and was causing his issue. good luck.
  #15 (permalink)
Old 03-10-2005, 09:47 PM
The in-tank pump ground sounds possible. My rear tank has been a question for a while. The sending unit has been inconsistant. I'll take a look. Thanks
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
