Triton 4.6 tune-up items - Ford Truck Enthusiasts Forums
Old 03-07-2005, 08:00 PM
RedStroker6's Avatar
RedStroker6 RedStroker6 is offline
RedStroker6 is starting off with a positive reputation.
well, this is for my buddy's dad's truck. 2000 150 4.6 4x4 automatic. my buddy been drivin it the past few days and says its suckin gas down like crazy and needs a tune-up....sine HE drives a Chebby Durasmack, he doesn't have a clue what his pop's truck needs. he's figurin on doing to plugs, cap, rotor, oil prolly too. what else does he need to look at? wires? just the general excellent up-keep items would be great, as his dad usually goes for the top of the line stuff when havin them worked on. i'll relay the info to him.
Old 03-07-2005, 09:39 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Well, it doesn't have a distributor so no cap, rotor or wires. It has COP's. Coil on plug. Each plug has it's own coil on it.
I highly recommend using either Motorcraft or Autolite double platinum plugs. All others do not seem to run well in these engines.
Replace the plugs, air filter, PCV valve and clean the MAF. This should get you going in the right direction.
Check out the FAQ threads in the 97-03 forum for some good tips on changing the plugs in a Triton engine.
Old 03-07-2005, 11:23 PM
well, that gives me a good place to start. COP is new to me...used to glow plugs. but thanks a bunch. gonna surf around the 97-03 for a bit
Old 03-08-2005, 09:58 AM
Bliath Bliath is offline
Bliath is starting off with a positive reputation.
LxMan1 Said it all pretty much. I would just add in also replacing the fuel filter and make sure the tires are inflated properly. In addition, at regular intervals having the coolant flushed and the transmisson serviced is good practice for long life and prevenitive maintainance.
Last edited by LxMan1; 03-09-2005 at 07:28 AM. Reason: corrected questionable spelling
Small exhaust JoeF250 1994.5 - 1997 7.3L Power Stroke Diesel 12 09-16-2016 08:56 PM
what kind of trasmission 1979fordf150rebel 1978 - 1996 Big Bronco 6 02-06-2012 10:00 AM
Type of Brake Fluid creich68 2009 - 2014 F150 2 02-05-2011 10:04 AM
4.6 slow at take off got2befast 2004 - 2008 F150 21 07-27-2010 06:29 PM
running 87 octane on a 93 octane tune?? bob1987f 2004 - 2008 F150 30 12-05-2009 11:19 PM
Tags
1999, 2000, 2006, 46, 54l, 97, distributor, ford, location, pcv, plug, replace, triton, tune, valve, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
