2.0/2.3L parts - Ford Truck Enthusiasts Forums
2.0/2.3L parts
Old 03-07-2005, 10:59 AM
Freighttrain's Avatar
Freighttrain Freighttrain is offline
Freighttrain is starting off with a positive reputation.
2.0/2.3L parts
I am building a Pony stock dirt track car and want to use the 2.0 since I can turn the little sucker 10,000RPM and keep it together.I need to know what stock 2 barrel intakes have larger ports?Truck,car,2.0,2.3.All the rules state is a stock 2 barrel intake manifold.Doesn't say it has to be stock to the engine.Just had to come on a ford 4 banger.I could hog it out but I would have to take a 50lb penalty(thats alot on a 2000lb car).Also,who makes the best cam for the RPM range I am looking at?This is my first time into round track.I have belonged to a team since last year working on a bomber car(Camero,Yuck,bow tie) but figured I would get myself something small and cheap to learn the ropes in.I am totally lost when it comes to gassers especially 4 bangers.Give me a diesel and I am fine!
Basic rules
Stock type intake
any flat top pistons
.500 max lift cam with .025 lash at valves
500CFM 2 barrel
any Non aftermarket head(SOHC only)
any steel valves of stock diameter
any competition valve jobs as long as grinds are concentric with guide
.750 hand blend is ok.
Old 03-07-2005, 07:21 PM
bobracing bobracing is offline
bobracing is starting off with a positive reputation.
1. the 2.0 and the 2.3 are not the same engine. BUT the 2.3 and the 2.5 are (more or less) the same. Also don't be confused by the 2 different 2.0s (do a search in this forum for more info).
2. There is no reason to run a 2.0 unless there is a cc limit or solid's can't be run on a 2.3. Don't know with your rules.
3. All the parts you want can be found at:
a. Esslinger
b. Race Engineering
c. Racer Walsh
note: don't have enough post to put links in yet.
4. We had good luck with Schneider Cams.
Make sure that you give them all the info you can about your engine (long rod or short, compression ect.)
5. Make sure you run good rods, pistons, rings, high volume oil pump, windage tray, studs (top & bottom) and balance the engine good. The better the parts, the better your chances the bottom end will stay together.
6. If you can't port the head, don't worry about turning much over 8k. Both the d-port and O-port head stop flowing any better at this point. A D-Port will flow better than a O-port if ported correctly but with solid lifter they are basically equal up to that point.
7. A good 8,000 rpm engine (that will stay together) will be in the 2500-3000 dollar range, just for parts and machine work.
8. and don't forget to check the 4m (dot) net site and SEARCH the post and archives, this will most likely answer all your questions.
Old 03-07-2005, 07:35 PM
thanks.The rules state 1lb per CC.That is the reason I wanted a 2.0.Here are the entire rules section for engines
Any stock 4 banger
Must be located in same location as stock engine for model of car
No turbo(dang)
No dry sumps
Any flat top pistons
Any steel rods
Crank must have stock stroke
Any non Aftermarket heads(any non aftermarket heads that are otherwise illegal maybe run with 50lb penalty)
No DOHCs
No more than 2 valves per Cyl
any steel valve of stock diameter
Any competition valve job allowed as long as angles are concentric with guides
.500 max lift cam measured with .025 lash at valve
any 2 barrel carb 500CFM max no variable Venturi
stock type intake manifolds(if the runners or mating surfaces are modified in any way 50lb penalty)
no more than 2 inches between base plate of carb and top of intake manifold
I might stick with the 2.3 since the car comes with one.seller didn't know if it was a runner or not but it has compression and spins over by hand easily.
Old 03-08-2005, 09:44 AM
Those rules are very open but if your using a Mustang, 2000# is really light and depending on the rules might be hard to reach. We had full bodied cars with stock floor pan (fr to rr) and came in about 2400#, 2200# (depending on rule) can be done. Biggest thing to remember is ounces equal pounds.
Make/modify the engine/trans mounts to be solid.
Use good pistons, I like Wiesco. Race engineering has some extra light weight pistons. Also we had good luck with the Total Seal rings too, they seal just like the name says.
> Any steel rods
Run the longest aftermarket rod you can. 5.7 is standard but 6.0 are starting to show up more. The pistons on longer rods are lighter too. Rule of thumb is the shorter the track the shorter the rod, but my theory is if you can get more power from long rods run them, the cam will need to be a special grind.
Doesn't say you can't lighten it, a knife edge crank will get you off the corner very fast. Don't forget that an aluminum flywheel will get rid of more rotating mass. Rotating mass is the enemy and do what you can to get rid of it. Balance everything together too.
Doesn't say anything about not porting it. A D-port is the best canidate with a esslinger port job.
Best to talk to Esslinger but the head can also be milled down about .150, this should give a little pop. I think our last engine had .010 off the block and .160 off the head.
I've heard that 305 HO (Yes Chevy) valve will fit into the head, this would give you a BIG vavle head with stock valves. It does say ANY stock steel vavle. CHECK BEFORE DOING THIS.
This is talking about a FI intake manifold and removing the center webbing. I've talked with people that say it WILL add HP but I've never run one. If you don't remove the webbing don't run it.
This tells me that solid lifter or a roller cams are legal. A roller cam will give less resistance but not sure money to power is worth it at this lift.
Couple other things to remember:
1. get a racing timing belt tentioner, THIS IS A MUST.
2. underdrive pulley on the crank is a must to slow down the water pump.
3. an Honda alternator (very small) on the smog pump bracket (very low) will also keep the battery charged and life much easier. People will tell you is sucks power, but it also keeps a full charge on the battery, makes life much easier and actually might give you more power with a fully charged ignition system.
4. A SCATTER SHIELD IS A MUST TOO.
5. adjustable cam pulley
Old 03-10-2005, 09:12 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
Ummh, I think that FoMoCo made a 2.0 that was the same as the 2.3 Lima... in 1985(?) they used EFI in Calif, and a carb'd fuel systems elsewhere, and some were 2.0 liters. Same block, but the bore was smaller. THe 2.5 has a longer stroke than the 2.3, but the same bore.
There was a 2.0 ohc used in Pintos and Capris in 1971-197? made in Germany and imprted. Similar to the 2.3, which came out in 1974 models, but no parts interchange.
tom
Old 03-10-2005, 10:34 AM
Yea, I thought about that and did make that first statement confusing.
We looked at a 2.0 (lima?) block one time and found nothing of use for racing. When someone starts talking 10,000 RPM the first engine that comes to mind is the early 2.0 (Pinto) engines. 2.0 (Pinto) had the solid lifters and is one reason they are so popular for racing in "stock" classes, they aren't RPM limited like the hyd 2.3 family head is.
Old 03-10-2005, 12:53 PM
460429_freak's Avatar
460429_freak 460429_freak is offline
460429_freak is starting off with a positive reputation.
also don't forget about a tfi dist (good for 10,000 rpm)
adjustable cam gear 1.9 escotr flywheel (19pnds and under) use a pinto carb (earl parker carburation) or a 350 holley dont use a 500 to much gas use some after market pully (power pully's)
on the mustang chasis find a right side lower a-arm (measure them before you buy) some was a inch longer ...
also some mustangs had "roller cams"
I ran pinto for 2 years (BONE STOCK) and could beaqt 2.5 chevy that was built
there was 2 differnt 2.0 the first early pinto comet ect. was solid lift head and could be ran 10,000 rpm the second was the ranger 2.0 in either case just use the 2.3 motor MUCH easier to find parts since they was made for 20 plus years..
Old 03-14-2005, 09:05 PM
idfergusson idfergusson is offline
idfergusson is starting off with a positive reputation.
There is an excellent book by David Vizard on modifying the Pinto 2.0 motor.A lot of the information in the book can be applied to other motors as well.I replaced the 2.0 in my 87 Ranger with a 2.3 and the ports in the 2.3 are larger than the 2.0 motor,so if you are using a 2.0 Lima then it might be beneficial to use the 2.3 head and intake.
351 engine/heads/cam selection george_c 1978 - 1996 Big Bronco 8 02-09-2011 06:42 PM
Scat forged crank and rods - rant topic Rusty_S General Automotive Discussion 4 05-05-2010 06:02 PM
4 Barrel intake for 2.8 Canadianice Bronco II 13 06-28-2007 07:30 PM
CAM specs hotrodfeguy Ranger & B-Series 0 01-18-2004 01:09 PM
Let's talk 360/390 cams for towing/hauling... Charles-65F350 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 03-08-2001 01:25 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
20, 23, 57, alternator, belt, cylinder, dport, engineering, esslinger, fomoco, ford, head, number, part, pinto, race, timing, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
